RE: Dropping 1"-2"
Login | |
RE: Dropping 1"-2" - 11/17/2008 1:41:34 PM
live2rice
Joined: 10/18/2006 From: Keene, NH/New Haven, CT Status: online
yet you live so close to englishtown.
_____________________________
quote:
ORIGINAL: hondadude I would not put a fram filter on a lawnmower engine... 1997 Fiji Blue Pearl CD7 1995 Sage Green Metallic CD5
RE: Dropping 1"-2" - 11/17/2008 1:43:00 PM
falkore24
LOL .... so close as in 3 hours?!?
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: Dropping 1"-2" - 11/17/2008 2:37:17 PM
live2rice
Closer than my 8 hours. Although I do have Limerock.
RE: Dropping 1"-2" - 11/17/2008 2:40:07 PM
finch13
East coast people confuse me... who wants some chowder!??!?!?!?!
USE ME TO SEARCH HAF PWOTY 2008!
RE: Dropping 1"-2" - 11/17/2008 2:46:29 PM
live2rice
We are talking about Englishtown and Limerock race tracks. http://www.etownraceway.com/ http://www.limerock.com/
RE: Dropping 1"-2" - 11/18/2008 7:28:01 AM
Ron505
quote:
ORIGINAL: finch13 But seriously you can get Tein Basic full coilovers for ~$600, you get a stiff spring though because they have to hold the car up at their lowest setting... which is why I went with H&R/Koni combo over coilovers. I hadn''t thought of that. I don''t want a stiff spring either. Back to the drawing board. I just want to drop around 2", but still have a comfortable ride. Is there any combo for under $1000?
2000 Accord EX Coupe Blue (B89P) 4 Cylinder V-tec Automatic
RE: Dropping 1"-2" - 11/18/2008 7:29:17 AM
live2rice
eibach sportline or pro kit with kyb, koni, or tokico struts.
RE: Dropping 1"-2" - 11/18/2008 8:13:38 AM
cjdm98
^X2 on that setup..
>>Click here to see my Accord<<
RE: Dropping 1"-2" - 11/18/2008 8:46:49 AM
finch13
Yep. Under $1k should be easy. Here''s my setup: H&R Race 1.75R/2.2F: $238 Koni Sport Dampers: $580 New strut bolts: $20 New spring isolators: $20 New damper isolators: $20 New sway bar links: $112 04+ TL-S 21mm sway: $55 And I''m at $1045... then factor in a camber kit if necessary, and that bumps it up to $1200
RE: Dropping 1"-2" - 11/18/2008 8:48:13 AM
live2rice
Dont forget alignment, another $75-100 or whatever they go for these days. However you do not need sway bars and such. and 1.75/2.2 is a pretty big diff, I want to see pics.
RE: Dropping 1"-2" - 11/18/2008 8:50:21 AM
cjdm98
Im sure you had negative camber on that setup finch.
RE: Dropping 1"-2" - 11/18/2008 8:57:57 AM
finch13
Not yet, hard to have neg. camber when it''s sitting your bedroom :D Pics for sure, I''m riding on Teggy-sized tired right now so I will probably be dragging the car on the ground. I already scrape on everything with the stock suspension. I''m going to my favorite alignment shop and hotrod buddy and he''ll let me sit in the car while he aligns it. $80. I''m also debating on whether to drop the perches on the Koni''s as low as they go... then it will be 2.5R/3.0F... we''ll see.
