RE: honda accord 92 ex overheating replaced EVERYTHING
  Printable Version
Honda Accord Forum >> General >> General Tech Help >> RE: honda accord 92 ex overheating replaced EVERYTHING Page: <<   < prev  1 2 3 [4]
Login
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/23/2006 9:42:55 PM
copa708
Status: offline
so i got the fan to turn by jumping it directly from the battery with a wire. but i did the same with the thermostat switch and i got nothin. so does this mean it's the thermostat switch or the wiring to the fan from the thermostat switch? also do you happen to know if this is a parallel or series circuit? or is it both? it sounds like the wire inbetween the 3 connectors (condensor, t-stat switch, coolant temp switch) and the fans is a series and it's messed up but those 3 connectors are parallel. is that right? if that's how it is, then i'm sure the wiring that's series is messed up because i tried jumping all 3 green switches and i got no reaction from the fan.
< Message edited by copa708 -- 4/23/2006 11:30:33 PM >
(in reply to deserthonda)
Post #: 46
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 1:02:38 AM
Hondamatic
Status: offline
Where are you located anyway?
(in reply to copa708)
Post #: 47
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 2:04:33 AM
copa708
Status: offline
in birmingham alabama. HEY I FIXED IT. actually my brother did. turns out there were some fuses i overlooked. i'm sure you guys already told me to look at it. but i only looked at one of the two (condensor fan). i didn't see the cooling fan in the bottom left corner of my fuses. my air conditioning feels so much better when idle now. thanks for helpin me out guys i feel i've learned a lot regardless of what i overlooked.
(in reply to Hondamatic)
Post #: 48
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 4:13:44 AM
lightshow
Status: offline
c-
Post #: 49
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 10:11:54 AM
deserthonda
Status: offline
quote:
ORIGINAL: copa708
Glad you got it fixed .,.....and it was something cheap to replace,, I wish you would have follow the directions i gave you step by step and not overlook anything ,, it would have made this ordeal a lot shorter and simpler ,,
Even with us techs we cannoit skip around or it will leave us chasing a GHOST..
I still think that if you are planning to work on your car regardless of year and model and make you should by a service and electrical manual.
Post #: 50
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 11:25:53 AM
Hondamatic
Status: offline
Well now go change your waterpump!!!
Glad you got it fixed and I was wrong..
Don't forget.. for the extra 40 bucks, you should replace your waterpump when you do your timing belt, too.
_____________________________
1991 Accord SE <- Crashed *see classfied section*
1987 Mitsu Montero (5spd 2.6l Turbo I/C) 2dr
1994 Mitsu Montero 3.5l SR - Loaded.
Post #: 51
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 6:28:34 PM
copa708
Status: offline
well i didn't skip anything, but when everyone told me to look at the fuses, i did but i didn't realize there were 2 fuses controlling the fans... or more maybe. i was looking at the giant fuse that's the relay and is just like the window which worked fine, but i didn't notice the other one that was tiny and right next to it. but yeah i'll knock out my timing belt and water pump this weekend.
Post #: 52
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 6:33:34 PM
sir_nasty
Status: offline
When you do that belt/pump if you have a digital camera take some pictures... if you don't have a camera but have some time a full writeup and how to do it for your vehicle/engine would be awesome... If it's easy enough to follow we'll post it in and upcoming section for other people to use..
Post #: 53
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 6:33:48 PM
deserthonda
Status: offline
if you plan oj doing the t-belt yourself,, this might help..
http://www.cybertrails.com/~puf/Honda2.2/997Honda2.2TimeBalNote.html
here is a list of parts you will need .. valve cover gasket, timing belt, balancer belt, water pump, coolant, cam seal, balancer shaft seal, balancer shaft seal retainer, oil pump seal, crank shaft seal, alternator belt, p/s belt ,,,... timing belt tensioner if noisy.....
When you have the timing belt off, spin the tensioner, if noisy replace,,,,, also replace alt and p/s belts only if needed if they look new , reuse them of course..
My advice ,, get quality honda parts, and get a manual HELMINC. COM
< Message edited by deserthonda -- 4/24/2006 6:40:31 PM >
Post #: 54
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/24/2006 6:36:43 PM
copa708
Status: offline
i looked at it in my service manual and it didn't look difficult at all. i could be wrong but the steps are simple and i compared it to my car to see if it matches up for an easier job. thanks yeah i'll probably take pictures with my camcorder.
(in reply to sir_nasty)
Post #: 55
Honda Accord >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6820
sir_nasty6303
falkore245601
00accordlx5s3797
deserthonda3574
finch133154
19accord973125
jimblake3116
smaglik2594
live2rice2502
New Vendors
Sportwing
