RE: Wet Paint
Login | |
RE: Wet Paint - 11/1/2007 6:17:33 PM
thunder_x
Joined: 10/2/2005 From: southern california Status: offline
the website lists all these metals that wet paint can be used on, but it doesnt say stainless-steel. anyone here try it on stainless-steel? i need to polish my muffler, and possibilly the entire piping
_____________________________
Project 91 ACCORD-193k miles All-Motor F22A1 http://www.cb7tuner.com/vbb/showthread.php?t=108490
RE: Wet Paint - 11/2/2007 7:37:22 AM
RTexasF
Forum Monitor Posts: 2282
Joined: 11/16/2004 From: Brownsville, TX Status: offline
I don't know how good a job it would do but try a spot to see. I would use a polish specific to metal in this case.
'04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: Wet Paint - 2/18/2008 9:02:32 PM
status
any one have pics of what it looks like on satin silver.?
2005 Accord lx 5-speed 35% tint 15 inch audiobahn sub
RE: Wet Paint - 2/19/2008 10:55:10 AM
falkore24
Rick: Wet Paint or Opti Seal? I've never used either, but have both marked down to try. The Opti Seal is from your "Time to strip it down" thread. I plan to show the tc in another year or so ..... after some mods. Right now it's begging for Claybar and I need to figure out what to put on after that.
''06 Scion TC Short Shifter radiator panel fully lit 3rd brake light 4pt rear bar sways S-pipe pulley poly bushings poly mounts ETD air horns pending strut bar ''00 V6-AT (RIP 3G) Pics in gallery
RE: Wet Paint - 2/19/2008 1:45:21 PM
RTexasF
Opti Seal is only used after a perfectly prepared surface has been accomplished by machine polishing for hours. It has zero correction ability and simply "locks in" what is beneath it. Unless you're planning on that kind of prep to the surface forget about it. I would clay & go with WP until you are ready to get a buffer/polisher.
RE: Wet Paint - 2/19/2008 2:14:37 PM
falkore24
quote:
ORIGINAL: RTexasF DuraGloss 105 to the rescue so I can start over for the new year. Tomorrow I'll seal it with two coats of Opti Seal. Wipe it on and walk away, no wipedown. Nice flake pop! You make it sound so simple ..... but thanks for the answer!!!
RE: Wet Paint - 2/19/2008 2:32:19 PM
RTexasF
Let's put it this way......if you are satisfied with the way your paint looks now (when clean) then go for the Opti Seal. It is expensive and has a learning curve but it's not a steep one. Just remember that any swirls or marks will show the same as before.
RE: Wet Paint - 2/20/2008 6:58:56 AM
falkore24
So clay, wet paint for 2 coats every 2 months and next year I do the Optiseal?
RE: Wet Paint - 2/20/2008 8:17:20 AM
RTexasF
You can use the Optiseal anytime you want to.
RE: Wet Paint - 2/21/2008 11:55:09 AM
falkore24
I mean that I'll use it after a year of Wet Paint so the finish is where I want it since you said that it will lock in any imperfections ...... also, I'm waiting for it to warm up a bit to get the paint fixed where the previous owner touched it up. I might just get a ground effects kit because both bumpers have paint damage and the front has a license plate hole. I'm not sure yet, but the car needs clay. I'm slowly getting this car up to my maintenance specs ..... I sense a large order of Royal Purple products in my future ..... RP Oil, tranny fluid and Purple Ice. ..... I'll probably flush the rad and go with Peak yellow lifetime coolant again. ..... MMO, flush, Seafoam ...... ditching the first of 2 catalytic converters.
< Message edited by falkore24 -- 2/21/2008 11:56:13 AM >
RE: Wet Paint - 4/18/2008 5:53:50 PM
Daver
HOLY Smokes batman!.. wow.. I just did my second coat of WP today.. took me about a hour yesterday and probably 30 minutes today with the second coat.. I have to say, after I did it I parked it outfront and my neighbor came over who has a vette and asked me who detailed my car. I told him of WetPaint which he hadn't heard of and let him borrow my bottle he is going to do it up tomorrow. I have to say after sitting in my driveway all day and getting a ton of pollen on it, all it took was a good drive at 60mph and got back home.. wallah, no pollen :) and it really looks like wetpaint.. Which I have had similar results with meguirs, however, with meguirs it never lasted too long and was no where near this slick.. I have always sworn by meguirs products.. this may have me switching completely
