RE: 17 or 18 inch wheels which will ride better
  Printable Version
Honda Accord Forums >> Your Ride >> Tires & Wheels >> RE: 17 or 18 inch wheels which will ride better Page: <<   < prev  1 [2]
Login
RE: 17 or 18 inch wheels which will ride better - 7/23/2006 4:39:45 PM
Status: offline
Read Post #4 Please...Thank You!
quote:
ORIGINAL: thunder_x
what is offset?
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
(in reply to thunder_x)
Post #: 16
RE: 17 or 18 inch wheels which will ride better - 7/23/2006 6:19:52 PM
Breeze
Status: offline
I just wanted to add that I have 17" Konig Imagine rims I have tire size p215/40R-17(Kumho ECSTA 711s-which are great) and I also tried 215/45R-17 Kumho ASX (which these tires didn't last long). The ride is so different from factory. The car just grips the road no matter what the weather is. I also wanted to add that after I got these rims I had to purchase camber kits for the front and the back. The tires on the front and back started to wear incorrectly and within three months the tires were gone. I bought SPC camber kits for the front and the back. I then lowered the car about 2". I learned the hard way about camber. I was told that Accords have no camber adjustments. I have a 96 so I don't really know about the newer Accords. I also wanted to tell you that you need to make sure you know what kind of metal the rims your getting are. The Konigs which are aluminum, that I purchased had a big problem with bending. I had to replace 2 of them because of the bad bends in them. One of the rims was sent back to Konig because the polish was coming off. Konig replaced for free. At this point I had to take another rim to be fixed because of a bend and I also have another rim with the polish coming off. I have since found out that Konig does not make 17" Konig Imagines anymore and Discount Tire cannot locate another rim. So be really carefull with the type of metal rim and try to find out if the rim is going to be discontinued. Hope this helps.. Breeze
(in reply to WheelBrokerAng)
Post #: 17
RE: 17 or 18 inch wheels which will ride better - 7/23/2006 7:55:53 PM
thunder_x
Status: offline
thunder_x's photo gallery
quote:
ORIGINAL: newaccord99
cool thanks for the info im looking now for wheels...what OFFSET should i be lookiong for?
that's all he says in post 4
(in reply to newaccord99)
Post #: 18
RE: 17 or 18 inch wheels which will ride better - 7/23/2006 11:52:29 PM
Status: offline
Read Post #5 then WheelBrokerAng
quote:
ORIGINAL: thunder_x
Post #: 19
RE: 17 or 18 inch wheels which will ride better - 7/25/2006 5:52:52 PM
Tommy997
Status: offline
quote:
ORIGINAL: Breeze
Are camber kits needed if the right offset is used?
Tom
(in reply to Breeze)
Post #: 20
RE: 17 or 18 inch wheels which will ride better - 7/29/2006 10:47:19 PM
Breeze
Status: offline
Tommy from what I understand any rim other than factory specs you will need camber kits. Hondas are prone to having a chamber problem because there is only a toe adjustment. If I were you I would ask around before you put the bigger rims and tires on. What ever place that you go to to get the rims and tires make them stand behind their advice. I suggest camber kits to anyone who is changing their stock rims and tires. Some people don't get camber kits but I can't afford to replace tires every three months. I have also found a place were I can take my car to get them to adjust the camber and alignment for a year. I paid $100.00 to get this special. For one year they will align and adjust the camber on my car as many times that it takes to keep them correct. Hope this will help.
(in reply to Tommy997)
Post #: 21
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6820
sir_nasty6303
falkore245601
00accordlx5s3797
deserthonda3574
finch133154
19accord973125
jimblake3116
smaglik2594
live2rice2502
New Vendors
Sportwing
