RE: Gettin' the most outta the K24A4.
Login | |
RE: Gettin' the most outta the K24A4. - 7/15/2006 8:46:54 PM
legionofone
piping would be all wrong... and the turbo manifild my be to close to the firewall remember turbos GLOW red at night after a hard run... and K24 is a DOHC
RE: Gettin' the most outta the K24A4. All Members Pleas... - 7/15/2006 9:08:19 PM
Joined: 8/30/2004 From: Canton/Massillon, Ohio 44646 Status: offline
Hi Guys! You know what! That was and is a Great Discussion there amongst you all and I want to commend you all for being Very Adult as you all usually are about 99% of the time.. I was in another forum that I contribute to as a Mod and with-in the 1st 4 posts there would have been an all out War with the words about this...all of you are great contributors in here and All of us MODS and The Admins Thank You for being what you are "The Best HAF Members ! WheelBrokerAng
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
RE: Gettin' the most outta the K24A4. - 7/15/2006 10:03:36 PM
YeuEmMaiMai
vtec gives you at most 10HP over stock on an I4 in the accord. I would guess that since the .1L increase in tne 6th gen I4(98-02) acocunts for the extra 5hp given to the 6th gen. The intake and exhaust account for 10 of the 15 hp increase. People often swap the EX intake and exhaust onto the non- vtec motor and get 10hp more. For the V6 6th gen cars swapping in the CL-S cams gives you about 6hp or so......The J30a also responds quite well to FI and it is not required to move the vtec engagement point a super charger and exhaust on a j30a will result in a 60hp increase in performance...
Jesus is Salvation White 2002 Acura CL type S. 68K and change Criminals thrive upon the intolerence of society''s understanding.....and political correctness
RE: Gettin' the most outta the K24A4. - 7/15/2006 10:54:47 PM
mbo1985
Hey Chiovnidca, do you currently have turbo? I was just wondering at what RPM your turbo really gets spooling if you have VTEC on the motor. I know the boost doesn't show up untill about 3k on my car (no vtec). I've gotta get rid of some of this lag...
1996 Accord LX Coupe Suspension Techniques Springs KYB AGX Struts Turbocharged
RE: Gettin' the most outta the K24A4. - 7/15/2006 11:28:51 PM
marbro
most turbos are universal, but it would require fabrication and planning, and you would be looking at probably more money then a basic kit...... its doable....... its just time and money thats the factor. You may want to consider hunting down a supercharger kit that may come out before a turbo kit
RE: Gettin' the most outta the K24A4. - 7/15/2006 11:39:40 PM
marbro
quote:
ORIGINAL: Chiovnidca How about using an aftermarket vtec cam? Maybe even one designed for turbos? I'm gonna keep my vtec with turbo, it seems to work pretty good. Surprises alot of people. :) There are regrinds that can be done on the stock cam, the only other way is to do a custom billet cam which would cost over 800ish a regrind usually doesnt cost more then 300. But there are defined regrinds that increase the lobes for low rpm and high rpm for vtec and unfortunately i cant remember the website that said this is a turbo regrind but the downside is the fact that sohc have equal intake exhaust have the exact same durations so you cant just define a longer duration for the exhaust vavles
RE: Gettin' the most outta the K24A4. - 7/16/2006 10:14:31 AM
marbro
yeah, i didnt word that right, what i ment to say was you cant change the cam overlap like you can on a dohc
RE: Gettin' the most outta the K24A4. - 7/16/2006 10:59:13 AM
RTexasF
Forum Monitor Posts: 2347
Joined: 11/16/2004 From: Brownsville, TX Status: offline
Alas, the 7th gen has nothing. It's on the way! http://www.racingtechnologyco.com/Accord_k24TurboKit.htm
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
