RE: IMPROVE GAS MILEAGE ..
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> RE: IMPROVE GAS MILEAGE .. Page: <<   < prev  2 3 [4] 5 6   next >   >>
Login
RE: IMPROVE GAS MILEAGE .. - 1/2/2008 1:20:25 PM
falkore24
Status: offline
falkore24's photo gallery
quote:
ORIGINAL: 00AccordLX5spd
Cat's aren't cheap either......
you have to feed them and get them shots and stuff ..... then there are the hairballs in your slippers .....
_____________________________
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to 00AccordLX5spd)
Post #: 46
RE: IMPROVE GAS MILEAGE .. - 1/6/2008 3:16:17 PM
Mark.Campbell.87
Status: offline
I found in my 2006 ford focus, that I got better fuel mileage when I was at 120KM/H ( I had no tack in the car so I dont know my RPM, roughly 3250 I would think). And in my '91 accord I find that I get better fuel mileage when I travel at 110KM/H(roughly 2500RPM) then when I travel at even 80KM/H(roughly 3300RPM).
Cheers,
-Mark
(in reply to marbro)
Post #: 47
RE: IMPROVE GAS MILEAGE .. - 1/6/2008 5:48:27 PM
nafango2
Status: offline
yea lx5sp is right,
i could buy a JDM H22 for the price that a cat costs. (not the animal)
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2)
Security System / Keyless entry
(in reply to Mark.Campbell.87)
Post #: 48
RE: IMPROVE GAS MILEAGE .. - 1/6/2008 6:03:43 PM
Accord_Ras
Status: offline
Today I added some Prestone injector cleaner, filled up the tank, and headed out of the city. I covered a total of approx. 150 miles and the fuel gauge is still a tad above 3/4's full!!. About 20 of the 150 miles was very steep, hilly terrain. I tried to maintain an average speed of 80km/h most of the time. I'm truly impressed!..extrapolating from this, under similiar conditions,  i should be able to get close to 600 mph!!!
1996 Accord with F2OB2 SOHC 4cyl. A/T
Lowered
(in reply to nafango2)
Post #: 49
RE: IMPROVE GAS MILEAGE .. - 1/6/2008 6:05:40 PM
Accord_Ras
Status: offline
That's 600mpg of course
Lowered
(in reply to Accord_Ras)
Post #: 50
RE: IMPROVE GAS MILEAGE .. - 1/7/2008 6:39:29 PM
honda97valdeez
Status: offline
Jon has a pic of a free cat.
97 accord ex-r sedan
2.7 v6
automatic
89 chevy silverado BIG RED
Post #: 51
RE: IMPROVE GAS MILEAGE .. - 1/23/2008 9:31:52 AM
status
Status: offline
so just so i'm clear theres
regular- $3.00
plus-$3.10
super-$3.20
so i usually put plus in. i thought that wasnt as bad as super but better that reg. i'm wrong?
2005 Accord lx
5-speed
35% tint
15 inch audiobahn sub
(in reply to honda97valdeez)
Post #: 52
RE: IMPROVE GAS MILEAGE .. - 1/30/2008 9:29:37 AM
ZionsWrath
Status: offline
Should you only cruise on flat stright roads? I use my cruise always, as long as traffic is light, even if there are turns and hills...
(in reply to deserthonda)
Post #: 53
[Deleted] - 2/13/2008 12:49:25 PM
Deleted User
[Deleted by Admins]
  Post #: 54
RE: IMPROVE GAS MILEAGE .. - 2/20/2008 11:48:15 AM
pwr
Status: offline
If your car is designed to run on unleaded regular and you're using premium, you're not only wasting money but getting less power and less mileage. Premium doesn't burn as quickly. Dyno tests prove this. Don't use it unless you need it.
PHIL in MOTOWN
2002 Accord EXL Cpe F23 5sp
1995 Del Sol Si 5sp
Past: 1993 Accord LX 5sp
1989 Acura Legend 1987 Acura Integra
1986 Honda CRX Si 1983 Honda Civic S
1972 BMW 2002 tii 1967 Mustang GT Fastback
1959 Austin Healey Sprite
Post #: 55
RE: IMPROVE GAS MILEAGE .. - 2/20/2008 2:09:25 PM
00AccordLX5spd
Status: offline
quote:
ORIGINAL: honda97valdeez
Ask and you shall receive:
2000 Accord LX Sedan F23A1 5spd
-Short Shift Adapter
-eBay SRI w/ K&N
1995 Accord V6 Sedan AT - AKA "the money pit"
1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
Post #: 56
RE: IMPROVE GAS MILEAGE .. - 2/26/2008 5:52:20 PM
erivkin10
Status: offline
I just purchased my Accord to replace the Volvo so I'm totally new to this forum. Reading through all the comments regarding improving gas mileage, I would like to add, clarify, and emphasize a few points that have served me well. Though the $ savings isn't much, the notion that I am minimizing my fuel consumption is my motivation.
a) Less spirited driving makes a difference. It also translates into less wear and tear on your car; i.e. tires, brakes, engine, and other drivetrain components. The wear/tear thing are the bigger bucks. If you want to be the first to the next red light, that is your choice but you are wasting fuel, your brakes, tires, adding wear and tear to the car's drivetrain, and possibly increasing the chance of meeting a fellow motorist...all for nothing.
b) Driving slower makes a HUGE difference; for every 5 mph over 60 mph, you are using roughly 5% more fuel.
http://www.fueleconomy.gov/feg/driveHabits.shtml    talks about it in different terms but draws the same conclusion.
c) Tire pressure can make a difference in mileage and it varies with temperature. Tire pressure drops 1 psi for every 10 degree (farhenheit) drop in temperature. The opposite is also true. It is one of the reasons I check my tire pressure more frequently when the ambient temperature changes significantly. Consult TireRack for a good article on this.
d) I'm a synthetic oil fan for two reasons. I think the engines last longer and for the mileage benefit. I've only tracked the latter in the Volvo and believe the mpg improvement is 7%-10% over dinosaur oil. I've also never serviced the PCV on that car after 158k miles and believe the synthetic oil has a lot to do with that.
e) Reducing drag and friction are a good thing. Keeping the outside of the car clean and waxed makes a difference.
f) I would suggest that the reason the mileage dropped with the seat heaters on was modestly because of the additional electrical load. The bigger cause was the outside temperature. Your car, any car's mileage decreases as the ambient temperature drops. Because I predominantly drive the Volvo, I am better able to track it's mileage based on temperature and driving conditions. It drops at least 15% in our mild winters with temps typically in the 20's and 30's. I believe there is more ethanol in our winter fuel blend as well and that also may contribute to the noted decline.
I hope my points are helpful. Keep having fun. BTW, my best mileage machine are my bicycles. They get tremendous fuel economy though they require more maintenance than any vehicle per mile traveled.
Post #: 57
RE: IMPROVE GAS MILEAGE .. - 2/26/2008 6:34:31 PM
gomarlins3
Status: offline
One of the biggest ways to help your gas mileage is to take most of the crap out of our trunks.  All the extra weight adds to the amount our vehicles have to haul around.
Post #: 58
RE: IMPROVE GAS MILEAGE .. - 2/27/2008 9:48:27 PM
accord___2000
Status: offline
Nice cat!!!
my accord
Track Your MPG Now
(in reply to gomarlins3)
Post #: 59
RE: IMPROVE GAS MILEAGE .. - 3/4/2008 8:47:01 AM
minorbliss626
Status: offline
Two things, im goin with the question about rpms... i have an 05 v6 6speed coupe and i was curious at what rpm most of you launch at with the v6... its comparable to my friends si we drive very alike but im new to foreign engines so please any feedback is appreciated... also does anyone elses glove box light never turn off?
Post #: 60
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6824
sir_nasty6303
falkore245601
00accordlx5s3797
deserthonda3574
finch133154
19accord973125
jimblake3116
smaglik2594
live2rice2503
New Vendors
Sportwing
