RE: IMPROVE GAS MILEAGE ..
Login | |
RE: IMPROVE GAS MILEAGE .. - 3/4/2008 9:59:38 AM
falkore24
why don't you search to find out that both items have been covered ..... or at least repeat the question in an appropriate thread. Thread jacking is rude and makes the thread have nothing to do with the title. Thanks for your future consideration.
_____________________________
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: IMPROVE GAS MILEAGE .. - 3/4/2008 2:45:52 PM
mattthemotorman
I dont mean to be annoying and ask pointless questions about my Honda, but Im pretty interested in increasing my Honda's gas mileage to a higher rate than it is now. For starters, I drive a 1997 Honda Accord LX with a 5 speed manual transmission, the motor is a 2.2L inline four, but doesnt have "V-Tec" on the valve cover. Dumb question, but does this make it a non-V-Tec motor? On the highway, I get about 30 mpg, and in the city around 26 mpg. I know by altering when I shift, how hard I press the gas, etc. can increase my gas mileage, but is there any motor mods I could do to really improve its gas mileage? And how about the shift points... when should I really be shifting? Honda has provided me with shift points (in the owners manual) but has anyone found anything else that works better? Edit: I just looked, and my motor is a F22B2, non V-Tec Anyways, thanks for any responses!
< Message edited by mattthemotorman -- 3/4/2008 3:25:55 PM >
RE: IMPROVE GAS MILEAGE .. - 3/9/2008 4:49:36 PM
BackStreet
This is most likely covered in here somewhere, but here goes: Clean air filter, clean the fuel injectors, fill the tires, light weight synthetic oil, remove extra weight from car, coast to a stop, easy on the gas, avoid traffic delays, program your gps for most economical - not fastest, start the engine and drive easy - don't warm up sitting still. If you want to cut your fuel bill: use public trasportation, car pool, combine trips, use a gps so you don't get lost, stay home, work from home, move closer to work, buy online, netflix/ppv, walk, ride a bike, call before you drive.
RE: IMPROVE GAS MILEAGE .. - 3/9/2008 8:02:07 PM
joshk5145
ok i have a96 accord i4 auto and only get about 320 miles per tank. is that normal? it seems low to me...
1996 lx accord f22b2 auto minor mods more coming soon
RE: IMPROVE GAS MILEAGE .. - 3/9/2008 8:15:49 PM
JimBlake
mattthemotorman... Shift points can go all over the place depending on your motives. For best fuel economy shift real early, like maybe even 2000 rpm. Low rpm & moderately open throttle use less fuel vs. high rpm & almost-closed throttle. But then if you suddenly 'need' to accelerate, you'll have to downshift. That might just discourage you from hammering the throttle all the time, which helps gas some more. Joshk... How empty do you go before filling?? Why don't you calculate your actual miles per actual gallons. Fill it full. Drive till it's anywhere near empty. Miles divided by gallons...
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: IMPROVE GAS MILEAGE .. - 3/11/2008 11:07:17 AM
ZionsWrath
03 2.4 I4 EX I only get about 300 per tank. I calculated ~23.5 running from full to the gas light. This is a drop from 330 per tank after I had an accident in the snow, requiring a replaced bearing and wheel.
< Message edited by ZionsWrath -- 3/11/2008 11:09:11 AM >
RE: IMPROVE GAS MILEAGE .. - 3/12/2008 6:18:55 PM
PSDSAINT
I just bought a 2008 Accord coupe V-6. I'm in love with the car but the gas mileage is not good even with the engine running on less then 6 cyl's. I have just passed break in and I'm still only getting 22 mpg driving it very easy. I would not have bought the car if I had known this and was expecting at least 27 mpg. Any ideas how I can imporve this? Thanks, Bill
RE: IMPROVE GAS MILEAGE .. - 3/12/2008 8:48:17 PM
ZionsWrath
quote:
ORIGINAL: PSDSAINT I just bought a 2008 Accord coupe V-6. I'm in love with the car but the gas mileage is not good even with the engine running on less then 6 cyl's. I have just passed break in and I'm still only getting 22 mpg driving it very easy. I would not have bought the car if I had known this and was expecting at least 27 mpg. Any ideas how I can imporve this? Thanks, Bill EPA estimates combined highway/city to be 22. http://automobiles.honda.com/accord-coupe/specifications.aspx?group=epa If you are getting the EPA, I believe you should be VERY happy. I only get 23.5 in my 4 cyl 2003 sedan. Maybe you should do a little more research next time?
RE: IMPROVE GAS MILEAGE .. - 3/13/2008 12:17:42 PM
PSDSAINT
Hi Zion and thanks for the link. That info I already knew so I'll explain in a little more detail for you. I just traded in a 2006 V6 Passat with 280 hp and 265 lbs of torque. The car averaged 26 to 27 mpg. My drive to work is 90% highway so when I saw the window sticker on my new Accord which said 28 mpg I thought to expect at least 26 considering the EPA stickers are now supposed to reflect more closely the actual mileage. So now break in is over and I'm getting 21/22 it just doesn't make sense. On my way home from work tonight I stopped in to my Honda dealer and asked a service tech about this. He said it is the "winter gas" and come summer I'll get better mileage. This doesn't make sense considering my Passat getting 26.5. Personally I think Honda has some explaining to do and I plan on getting to the bottom of this. I can't be the only one seeing this kind of disparity from the window sticker of 28. By the way your comment "I should be happy getting 22" only works for someone who is driving equally highway and around town. I'm going to call some of my friends that work for Honda in Torrance Ca. and ask them what is going on. I'll post what they tell me. Thanks Bill
03-EX-v6- SPARK PLUG WIRES - 3/27/2008 7:23:12 PM
jhonda1
does anyone know a good brand of SPARK PLUG WIRES for an 03 accord EX 3.0 V6... I HAVE NGK SPARK PLUGS, 6994 FOR THE CAR BUT HAVENT FOUND A GOOD NAME BRAND WIRE SET... JUST TAYLOR. thank you very much
RE: 03-EX-v6- SPARK PLUG WIRES - 3/27/2008 8:57:47 PM
JimBlake
NGK plugs are GOOD for that car. I'll trust you about the 6994, I didn't actually look that up. GOOD LUCK finding spark plug wires. Have you looked at your engine lately??
RE: 03-EX-v6- SPARK PLUG WIRES - 3/28/2008 7:19:38 AM
falkore24
LOL ..... wires .... pfff, we don't need no stinking wires!!!!
RE: 03-EX-v6- SPARK PLUG WIRES - 4/8/2008 2:20:25 PM
Ron505
I just purchased a 2000 Coupe 4cyl VTEC Auto, and I'm getting around 28 mpg, 85% highway, 15% City. I am pleased, however, I'd like to see about getting a little more mpg and power. Have any of you tried a Tornado (just like a HELIX THROTTLE BODY SPACER on TAS website)? It is supposed to create a vortex air flow. Also, would more air (CAI/SRI) be any advantage? Can you keep the stock exhaust with those intakes? I don't want a noisy car. Any input would be greatly appreciated.
RE: 03-EX-v6- SPARK PLUG WIRES - 4/8/2008 3:51:48 PM
oma93
I tried the teabag thing and I didn't see any improvement either.
93 Accord LX 4Dr 2.2EFI MT 210K Miles 32MPG mostly short trip in-town driving.
RE: 03-EX-v6- SPARK PLUG WIRES - 4/8/2008 10:52:57 PM
falkore24
Ron ... Tb Spacers will make your wallet a bit lighter to help the net weight of you vehicle .... other than that, they don't do a thing but add a little noise. Also, any intake on an Accord is louder than the exhaust above 3000 rpm's if you chose a quality exhaust. They are not required to be installed together, but are intended to be. The largest restriction to airflow in your car is the B-pipe or mid-pipe (same thing). It's the pipe from the cat to the muffler with the resonator on it. Upgrade that alone and you will notice a faster rpm change, up and down.
< Message edited by falkore24 -- 4/8/2008 10:56:39 PM >
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
