RE: is it better to have more torque or more horsepower?
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> RE: is it better to have more torque or more horsepower? Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: is it better to have more torque or more horsepower? - 7/24/2006 6:16:01 PM
marbro
Status: offline
J30a is also an exception cause its a v6 ^_-
(in reply to YeuEmMaiMai)
Post #: 16
RE: is it better to have more torque or more horsepower? - 7/26/2006 12:01:07 AM
JimBlake
Status: offline
quote:
ORIGINAL: marbro
I find it odd that everyone isnt saying both are important, cause what good is a car with 500hp and 120ft/lbs of torque? Yeah so what if you can get up to 200mph if you get to it in 5 minutes. Ideally you want about a 1:1 hp/torq Its just you dont want so much torque that your tires always spin out. When you think about it, your car really isnt going to its potential if your wheels are still spinning out in 3rd gear.
Having 500 hp & 120 lbf*ft wouldn't be so bad if you had the right gearing. Trouble is you won't find the right gearing in a normal transmission. That would have to be somewhere above 22,000 rpm. Gas turbine engines ???
Having 'more' torque or 'more' HP doesn't really mean anything, since they're not the same quantity.
And the definition of the units is sorta arbitrary. If we were talking in KW & N*M, this wouldn't be an issue. Or why don't we give power in ft*lb/sec? My Accord has 82,500 ft*lb/sec of power!!
(in reply to marbro)
Post #: 17
RE: is it better to have more torque or more horsepower? - 7/26/2006 12:14:03 AM
YeuEmMaiMai
Status: offline
IF you take a look at two of the fastest production cars available, the Buggati Vyron and the Hennessey Viper, each has a very flat and massive torque curve, this allows theses cars to reach instane speeds as the torque curve does not fall off until you get way up into the RPM range......
_____________________________
Jesus is Salvation
White 2002 Acura CL type S. 68K and change
Criminals thrive upon the intolerence of society''s understanding.....and political correctness
(in reply to JimBlake)
Post #: 18
RE: is it better to have more torque or more horsepower? - 7/26/2006 3:56:47 AM
legionofone
Status: offline
why is this even around dident i explain enough for everyone? both matter equaly without one the other is useless... end of story...
and yes gearing matters because when u gear something U INCREASE ITS TORQUE! if u dynoed a car in 1st gear... it would probably flatline any dyno... 400-600 Ft pounds is easily made by ur engine in first gear... 3rd gear is were u dyno ur car... 3rd gear is were it all matters... trust me i work with dynos... im a student at wyotech ;)
< Message edited by legionofone -- 7/26/2006 3:59:40 AM >
Post #: 19
RE: is it better to have more torque or more horsepower? - 7/26/2006 7:43:01 PM
YeuEmMaiMai
Status: offline
you might want to study some more.........
having a narrow torque band is useless You ultimate goal is to have a broad flat torque band that covers as MUCH OF THE RPM RANGE as possible. Since HP is a direct relation to RPM and Torque. IF your torque was 100% flat then your HP would raise linearly with RPM.
and gearing does NOT give you more torque, it allows you to make the MOST efficient USE of what torque YOU ALREADY have. The trade off is the speed at which you can drive forward at.
The only time you actually get more torque that what the engine has is when the car is equipped with an automatic transmission and that is 100% due to the multiplication given to you by the torque converter when the car first starts off. (this is the reason why autos are FASTER off of the line than the same car with a MANUAL)
Jesus is Salvation
(in reply to legionofone)
Post #: 20
RE: is it better to have more torque or more horsepower? - 7/26/2006 9:31:16 PM
Chiovnidca
Status: offline
quote:
ORIGINAL: YeuEmMaiMai
heeeeee
Post #: 21
RE: is it better to have more torque or more horsepower? - 7/26/2006 11:09:48 PM
legionofone
Status: offline
pl;z plz plz dont post in this again... u have no weight anymore... the TORQUE CONVERTER is mearly a fluid clutch... it in no way multiplies or enhances torque... it actualy destroys torque because instead of a clutch which is solid on solid a torque converter is a liquid turbine that slips 100% while at a stop allowing ur engine to turn while ur wheels dont... when u hit it it creates a vortex with its fins inside the liquid that is transfered to the other side of the converter and then runs threw the automatic tranny... this relationship actualy creates a HUGE HUGE loss in power because instead of the clutch (direct connection) u have a weak liquid... pushing ur car... and if u wanna come back with well why do drag cars use automatics its because they run bracket racing and thats about consistancy not and i make this very clear NOT about top speed or lowest time... a geo metro that runs 50s could dominate in bracket racing because with a good driver it would run exactly the same run over and over and over... now is there any more reasons u think that a auto is better? and if u say anything about the hennasy viper automatic i will stab u in the eye!
(in reply to Chiovnidca)
Post #: 22
RE: is it better to have more torque or more horsepower? - 7/27/2006 4:50:20 AM
YeuEmMaiMai
Status: offline
you really think you know something don't you? I really hate it when people have no idea what they are talking about and try to tell me i am stupid......
Here read this and then come back
http://auto.howstuffworks.com/torque-converter3.htm
"In addition to the very important job of allowing your car come to a complete stop without stalling the engine, the torque converter actually gives your car more torque when you accelerate out of a stop. Modern torque converters can multiply the torque of the engine by two to three times. This effect only happens when the engine is turning much faster than the transmission"
you are so full of it you stink........
I deal in facts not stupidity........
Jesus is Salvation
Post #: 23
RE: is it better to have more torque or more horsepower? - 7/27/2006 6:46:24 AM
legionofone
Status: offline
well... u find me a I4 accord auto to come race me and he wins... then u can laugh at me :)
Post #: 24
RE: is it better to have more torque or more horsepower? - 7/27/2006 3:58:22 PM
JimBlake
Status: offline
That's a simplification for the benefit of people who don't know how to do a correct force & moment balance. A gearbox will multiply torque much more effectively then a torque converter. It's not as bad as legion says, but an energy balance says that the power MUST be reduced by the amount of Joule heating in the torque converter.
The advantage of a torque converter only comes in the unsteady-state operation right off a standing start.
< Message edited by JimBlake -- 7/27/2006 3:59:50 PM >
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 25
RE: is it better to have more torque or more horsepower? - 7/27/2006 6:01:21 PM
marbro
Status: offline
yuppers, ultimately there is some energy loss because the torque converter doesnt create the same physical connection that the manual trans does. But as a side note, the advancements in automatics has been very significant so that problem is all that much smaller with newer cars. So in the end its left to the actual gearing of the transmission vs it being the difference between an auto and a manual
As a future note, a person who claims to have faith defeats themselves when they say they only deal with fact, because faith is a result of the absense of factual truth.
< Message edited by marbro -- 7/27/2006 6:03:27 PM >
Post #: 26
RE: is it better to have more torque or more horsepower? - 7/27/2006 6:12:36 PM
YeuEmMaiMai
Status: offline
that is why I limited my comments to a specific situation where it is applicable. There is energy loos with an auto but it does not come into play during launch because of the advantages you get when you launch. Once the the converter locks up, then the losses due to the converter are negated since there is a direct coupling just like in a manual trans.
Jesus is Salvation
Post #: 27
RE: is it better to have more torque or more horsepower? - 7/27/2006 6:13:35 PM
YeuEmMaiMai
Status: offline
quote:
ORIGINAL: As a future note, a person who claims to have faith defeats themselves when they say they only deal with fact, because faith is a result of the absense of factual truth.
Uhm you need to take this the apperiate thread and this one isn't it. Thanks
Jesus is Salvation
Post #: 28
RE: is it better to have more torque or more horsepower? - 7/27/2006 8:20:30 PM
marbro
Status: offline
And this response required a second post?
Post #: 29
RE: is it better to have more torque or more horsepower? - 7/27/2006 10:58:04 PM
legionofone
Status: offline
u might get a small temporary increase in torque... to the point of moving ur car but thats it... ur launch will be much slower and MUCH weaker then any manual... its a proven fact but whatever
Post #: 30
Honda Accord Forums >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6824
sir_nasty6303
falkore245601
00accordlx5s3797
deserthonda3574
finch133154
19accord973125
jimblake3116
smaglik2594
live2rice2503
New Vendors
Sportwing
