RE: car is chocking
Login | |
RE: car is chocking - 10/19/2006 1:32:33 PM
YeuEmMaiMai
check your alt output and make suire that it is at least 13.7V
_____________________________
Jesus is Salvation White 2002 Acura CL type S. 68K and change Criminals thrive upon the intolerence of society''s understanding.....and political correctness
RE: car is chocking - 10/20/2006 11:40:46 AM
sir_nasty
you can take the car to most auto parts stores and they will test the alternator and battery for free.... if that turns up nothing then you could always take it to a mech.
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: car is chocking - 10/20/2006 5:31:04 PM
mjparrie
Sir, I am shocked, I took it to a mech and they said the engine was blown. I am confused and completely amazed. Do they just blow? give up? Timing was fine no overheat no nothing. Depressed.
RE: car is chocking - 10/20/2006 6:16:56 PM
deserthonda
quote:
ORIGINAL: mjparrie Sir, I am shocked, I took it to a mech and they said the engine was blown. I am confused and completely amazed. Do they just blow? give up? Timing was fine no overheat no nothing. Depressed. ask them exactly what is wrong with the car , why did they say it is blown ?? have it in writing and have them give you an estimate to fix it ,,tell them you will think about it take car to another shop.. one that specializes in Hondas and see what they say
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: car is chocking - 10/20/2006 6:23:35 PM
mjparrie
What they said didn't make sense to me, as I don't think I am completely stupid. lol. Maybe I am. But they said it was shot due to the chambers filling up with oil and bad rings. I asked what they did to it to figure out it was shot. They pulled a plug that had oil in the tube. At this point I am thinking they are crazy cause that is the lower seals that this forum was talking about I just haven't had time to fix it. They said the rings are badly worn, which I know my car burns no oil and that usually is a sign correct? I am starting to think they just didn't want to mess with it. They told me to buy a used engine and go from there. I am like ok great I don't have the $$$ for that. Hell I am not even sure they checked the Alt. out or anything to do with the fuel system, but it didn't seem so.
94 Honda Accord Lx Coupe...........it was a dream car, not the best looking but absolutely no problems. Until now.
RE: car is chocking - 10/20/2006 6:35:13 PM
deserthonda
get away from there ASAP.....go to a shop that specializes in Hondas............chk engine lite on ?? have you checked for any stored codes ? is engine missing on any 1 particular cylinder or missing across the board?? have you pulled the plugs out?? are they fuel fouled?? if so , it might be a bad TW sensor .. make sure all injectors are firing properly? plug wires ok ? dizzy cap ? chk compression ? try these and let us know the results
RE: car is chocking - 10/20/2006 6:51:05 PM
mjparrie
Desert, no check engine light on, no stored codes, brand new sparkplugs old ones didn't really look that bad but changed them anyway, Distrib looks ok along with rotor, it feels like it is missing across the board, or atleast two cyl. the car when in park, drive or driving surges and goes to extreme low rpms. Lights, ac, radio everything on cause it to drop like normal then go back to normal, car has always done this. but one thing I almost forgot to mention, I am smelling an exhaust unburt emissions smell or something from it. Not a fresh gas smell but something else.
RE: car is chocking - 10/20/2006 6:53:39 PM
YeuEmMaiMai
humm have you checked your ICV? those things do get dirty and you can clean that sucker yourself with some goo be gone....or intake cleaner.......
RE: car is chocking - 10/20/2006 6:55:11 PM
sir_nasty
just because the rings are blown doesn't mean you'll see burning oil to begin with because the cat converter can prevent that (for a short while), watch your oil level and make sure that it isn't "burning" or loosing oil more quickly than normal, if not then I doubt that the rings are shot and so I wouldn't believe that the engine is blown. Like desert said see if you can get a written estimate/explination for what is wrong and take it to a honda mechanic, chances are they saw the oil and assumed it pushed up from the pistons since they don't know honda motors... Just watch your oil level (check it every 100 miles or so) and if it's dropping drastically then there may be some truth to the blown rings, but if not then they're full of it.... If you have a volt meter test the output of your alternator as well and see if it drops off almost completely after revving the engine....
RE: car is chocking - 10/20/2006 7:09:44 PM
mjparrie
Well I check the oil pretty regularly, don't think I have a problem there. I always make sure the car has three things. Oil, Water and Gas. lol. As far as the alternator I will check that tonight but I have been reading everthing I can on the net and all signs seem to point to the fuel filter or so as I can tell. Since Sir sayed this probably needs to be replaced I will tackle that tomarrow. I am thinking the same about these mech, they just don't know the car.
RE: car is chocking - 10/20/2006 7:11:16 PM
deserthonda
while engine is running pull out the hose to the egr valve ..( chk engine lite will come on but you can reset it later ) ,,anyho,, make sure that there is no vacc at idle at that hose,, also hook up a vacc pump to egr valve itself ,, supply vacc at idle, engine should die,, if engine does not die,, you got a bad egr valve or possibly plugged egr ports try and let us know to reset the ecu pull the back up fuse 7.5 amp in the underhood fuse box for about 20 seconds ( engine and key off of course )
RE: car is chocking - 10/22/2006 5:46:53 PM
mjparrie
Let me say thankyou for all you have done. Thank you to everyone that posted their info. The car is back running and who knows what it was. lol. Lets say it is back to normal, not perfect, but normal. After a fuel filter, plugs, wires, distrib, cleaning this and that...etc...it is back to pretty darn good for 180k. It does bottome out after a few strokes of the engine when it is running but it isn't that noticable. I am happy, but if anyone figures out a clue as to why it does that, well................ I know it isn't new, but it is all i have. Thanks again gang. Mjparrie
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
