RE: If You Engine Stumbles On Acceleration?
Login | |
RE: If You Engine Stumbles On Acceleration? - 3/1/2006 10:52:13 PM
Alekat
Depends on the year. Older Carb'd: - defective vacuum system, (affects spark advance ). - defective accelerator pump. - EGR valve.
RE: If You Engine Stumbles On Acceleration? - 4/24/2006 10:49:51 PM
darryltravis
Thanks to all for your invaluable help....I have resolved the problem, the cluster was crapping out. After a few trips to the yard, I found a unblemished cluster and presto! I have now cleaned the IAC valve and my car is running alot better too. What should the idle speed be and how do I adjust it....does the ECU have to be reset?
RE: If You Engine Stumbles On Acceleration? - 4/24/2006 10:51:47 PM
darryltravis
Hi Wheel, I have cleaned my IAC valve and the car runs smoother, what should the idle speed be? and how do I adjust it? Does the ECU have to be reset?
RE: If You Engine Stumbles On Acceleration? - 4/25/2006 1:14:11 AM
Joined: 8/30/2004 From: Canton/Massillon, Ohio 44646 Status: offline
Hi D.Travis.. IAC should check out @ between 8 and 15 oms.. The idle speed is controlled by the IAC valve and is activated by the ECU itself and this depends upon the running conditions of your engine, your A/C unit, poer steering, cold and warm running..set idle to what your VECI lable on your car has , if lable is not there car your Honda garage to get RPM listing... WheelBrokerAng
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
