RE: Braking Problems
  Printable Version
Honda Accord >> General >> General Tech Help >> RE: Braking Problems Page: <<   < prev  1 [2]
Login
RE: Braking Problems - 1/20/2007 9:22:39 PM
hondadude
Forum Monitor
Status: offline
WHAT IS THE CODE ????????????
if you want help we need info !!!!!!!!
(in reply to miami honda)
Post #: 16
RE: Braking Problems - 1/21/2007 1:32:49 AM
deserthonda
Status: offline
Yo Miami.........we are going around in circles here,,,,,,,,,,you need to reply to the question so we can try to help you the best we can,,,,,to do so we need for you to get the ABS code and post it here .........it might be something simple or it could be expensive but at this point all we can do is guess
GET THE CODE and post it here
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 17
RE: Braking Problems - 1/22/2007 5:59:58 PM
miami honda
Status: offline
ok got the code its three flashes and about ten seconds between them
like this flash 10sec flash 10 sec flash and then it dont flash no more just 3 flashes
(in reply to deserthonda)
Post #: 18
RE: Braking Problems - 1/23/2007 4:06:56 AM
PAhonda
Status: offline
One flash with no secondary code is ABS pump motor over-run
Below is a list of possible causes:
• Air mixed in the ABS brake fluid.
• Pressure switch stuck OFF
• Open circuit between the pressure switch and ABS control unit
• Open circuit in the P-SW circuit between the pressure switch and body ground, or a poor ground
• Drop in pump discharge volume
• Leaking outlet valve
• Leaking relief valve
• ABS brake fluid leakage
• Faulty ABS control unit
I would check the easy and cheap fixes:
  1. Check to make sure there is fluid.  I found it hard to see the level when mine was low.
  2. Bleed any air out of the modulator. (instructions below)
-1. Fill the reservoir to the MAX (upper) level with fresh brake fluid.
-2. Connect the rubber tube to the bleeder on the modulator unit, and set the other end of the rubber tube in a container.
-3. Loosen the bleeder, and start the engine to activate the pump motor.
NOTE: Take care not to spill the brake fluid from the container.
-4. Tighten the bleeder when the fluid starts to flow out of the bleeder.
-5. Stop the engine after the pump motor stops
NOTE: If the ABS indicator light comes on and the pump motor stops, restart the engine and repeat steps 3 through 5 above.
< Message edited by PAhonda -- 1/23/2007 4:07:46 AM >
1995 Accord EX MT
Post #: 19
RE: Braking Problems - 1/25/2007 5:51:24 PM
miami honda
Status: offline
so what the problem with my abs?
(in reply to PAhonda)
Post #: 20
RE: Braking Problems - 1/30/2007 4:08:50 PM
miami honda
Status: offline
anybody?
Post #: 21
RE: Braking Problems - 1/30/2007 5:04:06 PM
sir_nasty
Status: offline
Try the suggestions above your post about the fluid and bleeding the fluid and that may resolve your issues, if not then we'll start into testing.... is it leaking fluid at all?
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Post #: 22
RE: Braking Problems - 1/30/2007 5:05:50 PM
PAhonda
Status: offline
I posted the list of possible problems (three posts up) that would trigger the error code that you provided.  The first flash is the main code (1), then there was no second flash (0).  The problem is ABS pump motor over-run, and the error comes up beause the ABS pump motor is running for over 40 seconds without the ABS being used.
The easiest and cheapest problems from that list are:
1.  low brake fluid level
2.  air in the abs module
< Message edited by PAhonda -- 1/30/2007 5:06:16 PM >
1995 Accord EX MT
Post #: 23
RE: Braking Problems - 2/15/2007 6:26:17 PM
miami honda
Status: offline
yaaay my abs fixed itself  The motor just made a weird sound like it broke and then the abs light turned off :)
Now I wanna buy power folding mirrors!
Post #: 24
RE: Braking Problems - 2/15/2007 7:42:25 PM
poser_pilot6
Status: offline
poser_pilot6's photo gallery
LOL what?  It made a sound like it broke, and that "fixed it"?  So is your ABS working?  And where did the mirror thing come from?  Although they ARE sweet, a buddy of mine just got a Denali with power folding mirrors, its so cool lol.
1994 Accord LX four door
Bomz SRI w/ K&N filter
194k miles
Post #: 25
RE: Braking Problems - 2/18/2007 10:09:21 AM
miami honda
Status: offline
lol yeah my abs works now I think it had air int the lines or something. And the mirrors my friend is seling me his so I just thought they loked nice and wanted to know what you guys thought of them.
(in reply to poser_pilot6)
Post #: 26
Honda Accord Forums >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
