RE: valve adjustment - how necessary is it?
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> RE: valve adjustment - how necessary is it? Page: <<   < prev  1 [2]
Login
RE: valve adjustment - how necessary is it? - 11/23/2005 3:36:53 PM
tcodi
Status: offline
In response to a question of yours a few posts above:
Valves will have a slight bit of noise when cold because of the "lash" they are set to.
Valve lash is the clearance between the valve stem tip and the lifter, depends on the
engine but probably around .030 cold. This produces a noise when the engine is cold
because the lifters start moving before they contact the valves, so when they do they
give them a little smack. It makes a light pitter patter sound really fast like a bunch of
tapping.
Every engine needs cold lash because as it heats up the whole valve train grows. The valves
get a little longer, the cam gets a little fatter, etc. If the cold lash was set to zero you would
have valves sticking open when it was hot.
Setting lash is not hard, just intimidating if you've never done it because under the valve
cover on an dual cam engine it looks scary. It's really just a matter of getting some feeler
guages and tightening a bolt at the correct spot.
If it ain't giving you problems don't worry about it. The only possible effect of not re-adjusting
the valves on a high mileage engine is slightly less valve lift due to the wear on the cam and
follower. We're talking thousands of lift here. Maybe a horsepower or two at redline.
(in reply to FlyLow)
Post #: 16
RE: valve adjustment - how necessary is it? - 12/5/2005 1:44:58 AM
deserthonda
Status: offline
quote:
ORIGINAL: FlyLow
Local Honda dealer gave me an over the phone price of around $185 for the adjustment, said takes about 2 hrs. Should I do it?! So tempting I was intrigued by a few people saying earlier, that better performance may be realized. Although I think my 99 LX is doing well, I get 28-30 mpg. Any thoughts?
your local dealer is full of POOP..$ 185 is way way too much,, a new gasket is around 11 dollars and delers charge 1 hr for valve adjustment so it depends on their hourly rate 70-80- dollars per hr ??
get an adjustment every 30k..money well spent ,
< Message edited by WheelBrokerAng -- 12/5/2005 3:56:55 PM >
Post #: 17
RE: valve adjustment - how necessary is it? - 12/5/2005 2:20:29 AM
FlyLow
Status: offline
Interesting.. This dealer also sells Mercedes cars maybe that's why the estimate so high, I am just guessing for now though it's a bit late to call. Although I can't decide who is more right on this thread, the ones who say it's a waste of money adjusting valves, or the ones that are all about it. I believe a tie breaker is in order .
P.S. Sorry about your team earlier today Desert, go Bears!
(in reply to deserthonda)
Post #: 18
RE: valve adjustment - how necessary is it? - 5/27/2006 6:27:42 AM
Sendal
Status: offline
I just wondering ... We need to ajust on cold or hot engine ? and how much the clearance ? in and out ?
thank you
(in reply to eleiko)
Post #: 19
RE: valve adjustment - how necessary is it? - 5/27/2006 12:14:24 PM
deserthonda
Status: offline
quote:
ORIGINAL: Sendal
thank you
If you go to the DIY there is a HOW TO write up with step by step infos ..
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to Sendal)
Post #: 20
RE: valve adjustment - how necessary is it? - 5/29/2006 1:42:53 PM
YeuEmMaiMai
Status: offline
Valve adjustment is always done on a cold engine. From Huey Honda in St louis it was $125 in June 05 total including a new gasket/tube seal set. and oil change and 10% discount since my car has over 100k on it.
Jesus is Salvation
White 2002 Acura CL type S. 68K and change
Criminals thrive upon the intolerence of society''s understanding.....and political correctness
Post #: 21
RE: valve adjustment - how necessary is it? - 10/18/2006 7:17:54 PM
accordfan222
Status: offline
Thank you all for providing good knowledge, this forum was good to learn about the car. I read the article for how to do the valve adjustment. Only thing I have confusion with was clearance in model year 94 to 97. service manual shows INTAKE 0.26mm(0.010in) plus or minus 0.02mm, and EXHAUST 0.30mm(0.012in) plus or minus 0.02 mm. which numbers are correct ????? I think DO IT YOURSELF shows lot smaller number than this.
quote:
ORIGINAL: deserthonda
quote:
ORIGINAL: Sendal
thank you
97 Accord SE Automatic 4dr
Post #: 22
RE: valve adjustment - how necessary is it? - 10/18/2006 7:47:36 PM
sir_nasty
Status: offline
if you've got the numbers from a service manual and it's the right manual then stick with them and you'll be fine
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''s great but it''s not all beer and skittles
(in reply to accordfan222)
Post #: 23
RE: valve adjustment - how necessary is it? - 10/18/2006 9:54:56 PM
deserthonda
Status: offline
quote:
ORIGINAL: accordfan222
quote:
ORIGINAL: Sendal
thank you
you are correct i went back and checked it out i should have said .010 and .012 inc instead of mm ..thanks for bringing it up,, i will change it
No Help from me
Post #: 24
RE: valve adjustment - how necessary is it? - 10/19/2006 3:39:06 AM
YeuEmMaiMai
Status: offline
one thing to note that even if your valves are NOT making any noise the lash should be checked and adjusted at the intervil that honda states simply because if they are too tight, they will still wear without making any noise........Also some F series motors are just plain noisey due to excessive wear on valve train component that does not affect engine life.... just makes it noisey
Jesus is Salvation
Post #: 25
RE: valve adjustment - how necessary is it? - 10/21/2006 12:26:38 AM
Slusher
Status: offline
I second what YeuEmMaiMai said. I have checked and adjusted my valves 3 times in 4 months because the valves seemed noisy. But everything is within spec and the valves are only really noisy when the engine is cold.
You get the head, the tail, the whole damn thing.
95 EX Auto
OBX 4-2-1 Header
Type R Strut Bar
SRI
174k miles
(in reply to YeuEmMaiMai)
Post #: 26
Honda Accord Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2648
smaglik2594
New Vendors
Sportwing
