RE: Rear anti-roll/ sway bar, tie bar
  Printable Version
Honda Accord Forum >> Your Ride >> Suspension >> RE: Rear anti-roll/ sway bar, tie bar Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Rear anti-roll/ sway bar, tie bar - 1/26/2007 2:23:29 PM
RTexasF
Forum Monitor
Status: offline
RTexasF's photo gallery
Cool!
Thumbnail Image
Attachment (1)
_____________________________
''''04 2.4l 5M EX Sedan
Neuspeed short shift kit
V-6 6 speed front strut/firewall brace
17mm rear anti sway bar
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Clean Sweep
JL Audio Amp
200W Bazooka sub
V-6 OEM 7 spoke alloys
(in reply to rob3201)
Post #: 16
RE: Rear anti-roll/ sway bar, tie bar - 1/28/2007 3:57:03 PM
Peg_Leg
Status: offline
Peg_Leg's photo gallery
i would also like to know if the tl rear sway bar will work on my 2006 accord vp thanks
(in reply to RTexasF)
Post #: 17
RE: Rear anti-roll/ sway bar, tie bar - 1/28/2007 7:59:43 PM
RTexasF
Forum Monitor
Status: offline
I don't think a VP has a rear sway bar or the links for one but I'm far from sure of that. Look under the car to see if it has one. If so you can upgrade easily, if not a little more work will be involved.
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
(in reply to Peg_Leg)
Post #: 18
RE: Rear anti-roll/ sway bar, tie bar - 1/28/2007 9:51:36 PM
Peg_Leg
Status: offline
if it doesn't have one  i guess i could see if i can order the links or check a junk yard
Post #: 19
RE: Rear anti-roll/ sway bar, tie bar - 2/3/2007 11:39:45 AM
jancoka
Status: offline
< Message edited by jancoka -- 2/3/2007 11:40:21 AM >
Post #: 20
RE: Rear anti-roll/ sway bar, tie bar - 2/3/2007 11:40:26 AM
jancoka
Status: offline
I have 2002 AT V6 Accord, will that 52300-SEP-A11, 20mm Stabilizer Spring (Sway Bar) work with my car?
thx
(in reply to jancoka)
Post #: 21
RE: Rear anti-roll/ sway bar, tie bar - 2/3/2007 12:16:56 PM
RTexasF
Forum Monitor
Status: offline
No, the swap is for 7th gen Accords but there might be an aftermarket one that will fit.
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 22
RE: Rear anti-roll/ sway bar, tie bar - 2/14/2007 9:56:29 AM
rob3201
Status: offline
So I purchased the 20mm sway bar. Does the car need to be on a lift or can I simply go underneth the car to install ? Also, any website to get the installation directions ? I know its easy but just in case.
2006 Accord V6 Coupe 6 Speed
20mm Acura TL sway bar
Painted to match OEM Fog lights trim , OEM front grill, rear view mirrors
15 % tint
Power Slot Cyro Rotors and Hawk HPS pads
Post #: 23
RE: Rear anti-roll/ sway bar, tie bar - 2/14/2007 11:53:58 AM
RTexasF
Forum Monitor
Status: offline
Some have crawled under with no problem I chose to back it up on some ramps for more working room. I'm not aware of any printed directions.
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 24
RE: Rear anti-roll/ sway bar, tie bar - 2/15/2007 11:02:49 AM
otsb708
Status: offline
Here is the link to the Neuspeed install.....http://www.neuspeed.com/data/installs/25.20.19.4.pdf  This might give you an idea of how straight forward the install is.  This is a pic of my rear bar....
Thumbnail Image
Attachment (1)
Post #: 25
RE: Rear anti-roll/ sway bar, tie bar - 2/15/2007 1:16:25 PM
sir_nasty
Status: offline
quote:
ORIGINAL: rob3201
Like tex said you could probably do it by just crawling underneath but having some ramps or even a few blocks of wood or flat rocks to back up onto would help give you some extra room and make your life easier.... don't forget to block your tires properly and leave the car in gear or in park when you do this...
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Post #: 26
RE: Rear anti-roll/ sway bar, tie bar - 2/15/2007 6:14:20 PM
rob3201
Status: offline
Thanks. I have the the bushings and clamps. Do I need new bolts or do I use the originals ? hows the ride ?
< Message edited by rob3201 -- 2/15/2007 6:19:27 PM >
(in reply to otsb708)
Post #: 27
RE: Rear anti-roll/ sway bar, tie bar - 2/15/2007 7:42:09 PM
otsb708
Status: offline
quote:
ORIGINAL: rob3201
In my kit they supplied new one's but the old bolts will work just fine.  The ride is 100x better than with the tiny stock bar.  I really felt the difference the first corner I took.  Good luck with your new bar!
Post #: 28
RE: Rear anti-roll/ sway bar, tie bar - 3/14/2007 9:33:45 AM
rob3201
Status: offline
Install was very easy (20mm sway bar) I have a few questions.
1. Is it overstear OR am I not used to the responsiveness of the new setup ?
2. Is it me or is the rear higher in ride height ?
3. Does this cause extra stress on other components of the suspension ?
Performance wise the new bar really flattens out the back. The car is better balanced. At high speeds the steering is very sharp with 75% less rear lag. Steering is very responsive to driver input. . Its only been about 50 miles so its premature. After about 500 miles Ill keep you posted as I get used to the new setup.
15 % tint
Post #: 29
RE: Rear anti-roll/ sway bar, tie bar - 3/14/2007 10:23:20 AM
RTexasF
Forum Monitor
Status: offline
1. Is it overstear OR am I not used to the responsiveness of the new setup ?  I think you're still getting used to it.
2. Is it me or is the rear higher in ride height ?                                                Height is unchanged.
3. Does this cause extra stress on other components of the suspension ?        Possibly the link arms but I'ver never heard of problems.
AEM Shorty
DC Sports SS Header
Kicker Speakers
JL Audio Amp
200W Bazooka sub
Post #: 30
Honda Accord >> Your Ride >> Suspension
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6826
sir_nasty6303
falkore245634
00accordlx5s3797
deserthonda3574
finch133204
jimblake3131
19accord973125
live2rice2596
smaglik2594
New Vendors
Sportwing
