RE: Header Gasket ?
  Printable Version
Honda Accord Forums >> Your Ride >> Headers, Intake, & Exhaust >> RE: Header Gasket ? Page: <<   < prev  1 [2]
Login
RE: Header Gasket ? - 2/9/2007 7:04:54 PM
19Accord97
Status: offline
19Accord97's photo gallery
I bought some high temp red rtv and ordered some thick gasket so I can cut out my own.  It was $10 for a 10x10 of gasket so i may just use a combination of the two.  I couldnt find the form a gasket anywhere thats for high temps.  ill let you know.
I havent had any check engine lights until now.  I also replaced my o2 sensor in the manifold when I got them installed.
_____________________________
Scopin out my old turf......
(in reply to 94scaccord)
Post #: 16
RE: Header Gasket ? - 2/12/2007 9:38:26 PM
19Accord97
Status: offline
FINALLY!  The problem has been solved, and hopefully will continue to work flawlessly.  I made the gasket with a sheet of 10x10 Mr. Gasket gasket which was a pain and wasnt a pretty eye sight.  Then the High Temp red RTV silicone.  I let it sit over night, drove it to school, back, and then jacked it up, retightened the bolts of the flange which were already loose, then went to Autozone to get the light reset and it hasnt turned back on!  Yay! I also bought STP's complete fual system cleaner $5.99 to get rid of all that extra gunk b/c it was pouring so much fuel in.
If you guys have any problems like this, let me know and ill be glad to help!
(in reply to 19Accord97)
Post #: 17
RE: Header Gasket ? - 2/12/2007 9:46:08 PM
poser_pilot6
Status: offline
poser_pilot6's photo gallery
I dont suppose you took any pictures, did ya?  I think when I get my OBX header, Im just going to do some preventative work, and make my own gasket from the start.  Or maybe get one of those high speed copper thingys, or whatever metal they are made out of.
1994 Accord LX four door
Bomz SRI w/ K&N filter
194k miles
Post #: 18
RE: Header Gasket ? - 2/12/2007 9:54:01 PM
Slusher
Status: offline
Glad to hear that your situation is all set!  And that I know what to do if mine goes:)
You get the head, the tail, the whole damn thing.
95 EX Auto
OBX 4-2-1 Header
Type R Strut Bar
SRI
174k miles
Post #: 19
RE: Header Gasket ? - 2/12/2007 10:07:02 PM
19Accord97
Status: offline
quote:
ORIGINAL: poser_pilot6
Nope, I didnt.  Sorry!  Here are some things I would do though:
-Make sure you spray all the bolts/nuts you will be removing w/ WD40 or Liquid Wrench in as much advance as possible.  I was spraying them 2 times a day 2 weeks prior to getting my headers.  It will make it alot easier, trust me.
-When you get your headers, use a level and make sure all the flanges are level.  Mine have warped a little.
-Next, don't use the gaskets that come with the headers.  They are junk.  At Autozone and Advance Auto parts they have 2 versions, a Felpro, about $11 (the one I used) and they have another one which is about $16 and that is metal with raised edges.  I would have gotten that, but you have to wait 3 days b/c they were out of stock.
-For the actual flange gasket, look in this post, youll see a link, and there is a picture of a copper gasket that is the one you will need.  Its about $10 from summit racing.  I am not sure if they have different sizes, so check that first.  Of course, OBX uses a gasket that local autopart stores dont carry!
-OH and here might have been my trouble.  Make sure you keep retightening those bolts after they have a couple of warm up and cool down cycles.
-Lastly, when you guys get your headers installed, know that your current o2 sensor may be stuck in your manifold.  Mine was, so I bought a Bosch one.  Now heres the thing.  The hole for the o2 sensor wasnt placed the best.  You have to unbolt the holder for the connections of the two o2 sensor wires and it stretches to its MAX to reach the o2 sensor.  So hopefully your OEM sensor has the same length wires and will reach.
Anything else?
(in reply to poser_pilot6)
Post #: 20
RE: Header Gasket ? - 2/12/2007 10:14:42 PM
poser_pilot6
Status: offline
I was planning on using the Liquid Wrench, because I remember you strongly advised that a while back.  So I will get some better gaskets before I do the install, and check every day for the first week or so to make sure they stay tight.  And I already have a Denso OEM oxygen sensor just waiting for me to scrounge up the cash for this little adventure lol.  I just really want to wait til I get the cat back, so I can do it all at once.
194k miles
Post #: 21
RE: Header Gasket ? - 2/12/2007 10:23:31 PM
19Accord97
Status: offline
Sounds like you are all ready!  I am going to be checking all my bolts about every two weeks after I make sure these are going to stay tight.
If you can't wait, you should be able to do the headers w/o removing the rest of the exhaust.  I didnt remove the old manifold so I am not for sure, but when we replaced the gaskets we only had to undo the bolts for the manifold and flange to slip the manifold gasket on.  And for the most recent gasket, I was able to take out the second half of the headers w/o removing or loosening anything else.
While you are under there, check to make sure you dont have any broken rubber mounts for your exhaust.  And getting the nuts off from the cat will take awhile!
Also, my theory is that because the OBX headers dont have the stainless steel felx section it makes the exhaust section more rigid than normal and that is why the bolts tend to loosen up quickly.  I also noticed that one of the rubber hangers that I replaced when I put my new exhaust on is torn, so im suspecting that it broke that b/c of the lack of flex.
And with my exhaust/headers when I put it in reverse it makes this grunting/grinding noise because the midsection (right about where the rubber exhaust hanger broke) is barely scraping the sheet metel shield underneath the car.
Post #: 22
RE: Header Gasket ? - 2/12/2007 10:27:51 PM
poser_pilot6
Status: offline
I just want to wait so I can do it all at once, it will be easier I think.  Plus the added power will all be there at once, so it will seem really fast lol.  Not to mention the sound lol.  But yeah, I will check those hangers too, beforehand.  Good call.
194k miles
Post #: 23
RE: Header Gasket ? - 2/12/2007 10:39:05 PM
19Accord97
Status: offline
Yeah!  I know what you mean power wise! It was def. nice w/ the addition of the two!  Smells horrible though for the first few miles! haha  Jeesh, I keep forgetting things.
But if you want toyur headers to look good, make sure you clean them off with a chrome or something like it cleaner.  If you leave your fingerprints on there and start the car it will burn them into the headers and you wont be able to remove them.
Sound wise, I didnt really notice any b/c the intake over powers everything esle.
Post #: 24
RE: Header Gasket ? - 2/14/2007 2:33:42 PM
19Accord97
Status: offline
To Poser and Slusher, I took a couple pics of the flange where the gasket went bad. Sorry there arent more/better ones but I had to take quite a few of the snowstorm!  You can see the Red Silicone that got squished out and in the other, you can tell (sorry its not a better pic) how much the o2 sensor is going to be stretched when you get your headers.  Hope this helps.
Thumbnail Image
Thumbnail Image
Attachment (2)
Post #: 25
RE: Header Gasket ? - 2/14/2007 11:17:29 PM
Slusher
Status: offline
thanks man, appreciate your help and experience!
95 EX Auto
OBX 4-2-1 Header
Type R Strut Bar
SRI
174k miles
Post #: 26
RE: Header Gasket ? - 2/14/2007 11:57:24 PM
19Accord97
Status: offline
No problem! Always glad to help
(in reply to Slusher)
Post #: 27
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
