RE: Timing Belt? spark plug test
Login | |
RE: Timing Belt? spark plug test - 2/23/2007 10:04:15 AM
TexasHonda
I would suggest removing the air intake and spray a bit of throttle body cleaner or starter fluid into the intake while turning the engine over. If it catches for a second, this would confirm a good spark and lack of fuel delivery w/ one easy test. Recently another fellow had similar symptoms on a 90 Accord on another forum. We went back on forth on fuel supply/spark issues, but he could not coax even a hint of starting w/ the above test. Problem was fixed w/ a new coil. good luck
_____________________________
See you down the ROW 1994 Accord EX
RE: Timing Belt? spark plug test - 2/23/2007 3:56:04 PM
deserthonda
if you have a fuel pressure gauge great you can properly chk fuel pressure if not,, do as it ws suggested remove the intake tube at throttle body open the plate and spray some carb cleaner in the throttle body ,, if car starts it confirms lack of gas . If so now you got to chk for power and ground at fuel pump,, if you have both and no fuel pressure most likely a bad fuel pump,, if no power chk the fuse first but it could be a bad main relay seen a bunch of those go bad ,,
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: Timing Belt? spark plug test - 2/23/2007 4:55:49 PM
RSM93HONDA
Car is getting gas and spark. So i stumped. Im gonna check the compression and get back to you. Thanks. Any other suggestions would be great. Oh by the way sprayed with throttle body cleaner and still no start. Thanks.
1993 Accord SE
RE: Timing Belt? spark plug test - 2/23/2007 5:04:49 PM
TexasHonda
No start w/ throttle body spray into the intake suggests a spark problem. Your symptoms and results are similar to the problem I mentioned above. He was convinced he had good spark because he had installed a new coil. However, when he swapped a coil from a running Accord, it instantly started. The coil can deliver a spark that is difficult to recognize as weak, but will not come close to starting the engine. A quick & dirty test for fuel pressure is to crack the banjo bolt on the fuel rail end (driver's side). It should have a healthy spray of fuel. Be Careful and use a rag to avoid gas everywhere! This doesn't rule out low pressure, but does rule out zero pressure. Persistance and attention to detail are essential in a difficult no-start. The fellow mentioned above struggled for several weeks before the coil problem was identified. good luck
RE: Timing Belt? spark plug test - 2/23/2007 5:19:22 PM
deserthonda
if you are getting good spark and fuel..........does the chk engine lite come on when you turn the ignit switch on and goes off after 5-6-seconds ?? if so,, you now need to chk to make sure t-belt did not jump.. .. also try something, remove the plugs, clean them, put a bit of tranny fluid in the cylinders before you reinstall the plugs ,, while you have the plugs out you might want to do a compression test
RE: Timing Belt? spark plug test - 2/23/2007 5:52:36 PM
RSM93HONDA
I did a compression test and am having no luck. It is reading only 30 psi. Im going to check spark again. be back.
1993 Accord SE
RE: Timing Belt? spark plug test - 2/23/2007 6:52:29 PM
sir_nasty
if it's reading that low it could be timing issue, put a little bit of tranny fluid in there and then test it, you should be at least 130 psi or better..
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: Timing Belt? spark plug test - 2/23/2007 6:56:15 PM
deserthonda
quote:
ORIGINAL: RSM93HONDA I did a compression test and am having no luck. It is reading only 30 psi. Im going to check spark again. be back. DO NOT waste your time checking for spark ,.. if your compression is only 30 psi all the way across the car will not start,, chk to make sure the timing belt did not jump if did repair accordingly if it did not engine might have what we call a cylinder wash too much raw gas been pouring in the cylinders,,,,,,if t-belt is ok try what i suggested before , remove the plugs clean and dry them and put a bit of tranny oil on the cylinder, reinstall the plugs also chk the oil make sure it is not full of gasoline .. try and repost
