RE: Timing Belt? spark plug test
Login | |
RE: Timing Belt? spark plug test - 2/24/2007 5:16:24 PM
RSM93HONDA
I checked the timing and it appears to be off. With the cam lined up properly the flywheel shows no markings. I hit it with a timing light and also got no markings. The timing light did light. Any suggestions? Thanks.
_____________________________
1993 Accord SE
RE: Timing Belt? spark plug test - 2/24/2007 8:00:49 PM
TexasHonda
You could use motor oil also. Oil allows rings to seal and create better compression. If compression doesn't improve w/ added oil, suspect valve leakage or mis-timed valves.
See you down the ROW 1994 Accord EX
RE: Timing Belt? spark plug test - 2/24/2007 8:13:42 PM
PAhonda
If you lineup the flywheel to TDC, how many cogs are you off on the cam? There is also a possibility that you had the cam turned the wrong way, because the cam goes through two revolutions for every one turn of the crankshaft.
1995 Accord EX MT
RE: Timing Belt? spark plug test - 2/25/2007 5:49:40 AM
RSM93HONDA
Im not quite sure what the deal is with the timing. So far it looks liked it jumped a couple of cogs. I will let you know when i have more info. Thanks.
1993 Accord SE
RE: Timing Belt? spark plug test - 2/25/2007 10:28:14 AM
TexasHonda
quote:
ORIGINAL: RSM93HONDA I checked the timing and it appears to be off. With the cam lined up properly the flywheel shows no markings. I hit it with a timing light and also got no markings. The timing light did light. Any suggestions? Thanks. As long as the distributor is turning, the spark will be generated and timing flashes will occur. If they are not illuminating any timing marks, you know the timing is far off. You'll have to replace timing belt and reset timing if you confirm the timing belt is misaligned. Hopefully no valve damage. good luck
RE: Timing Belt? spark plug test - 2/25/2007 1:06:31 PM
Tony1M
quote:
ORIGINAL: RSM93HONDA I checked the timing and it appears to be off. With the cam lined up properly the flywheel shows no markings. I hit it with a timing light and also got no markings. The timing light did light. Any suggestions? Thanks. To see that the cam was "lined up properly", you must have determined that with the valve cover removed, the upper timing cover removed, and the dstributor cap removed, correct? If the 9 o'clock and 3 o'clock marks on the back of the cam pulley are even with the top of the head, the 12 o'clock mark is in the 12 o'clock position, and the distributor rotor is pointing to the #1 plug's cotact in the distributor cap, this indicates a TDC position on the valve-train, or ignition-timing, "side" of the engine. Under that rectangular rubber plug on the front of the engine, if the flywheel mark is lined up with the V-notch indciator, this indicates TDC on either the compression or the exhaust cycle of the piston "side" of the engine. If you have TDC on the timing side, but don't have it on the piston side, the timing belt is either not in its proper position on the crank and cam pulleys, or the timing-belt tesioner is not doing what it's supposed to do and the belt is loose enough to affect the accuracy of the timing side operation. The latter will certainly affect compression readings because the exhaust and intake valves are not both closed for the entire compression stroke. For exaample, the intake may close well before the piston gets to the bottom of the intake stroke, or it may be still be open when the piston starts the compression stroke. As I said, if the belt has slipped into the wrong position, or the belt is too loose, likely it is because the tensioner is not doing its job. So, if you still have the upper timing cover off, using your finger, press on both sides of the timing belt somewhere below the center of the sides of the cam pulley. Is belt tension adequate, and equal, on both sides of the cam pulley? Try to raise the belt off the cam pulley from the water-pump side of the pulley. Can you do it? If you can, something's very wrong. Good luck.
< Message edited by Tony1M -- 2/25/2007 1:10:38 PM >
Tony 1992 Accord LX, 4AT, 4 dr, no AC, no power anything
RE: Timing Belt? - 2/26/2007 8:21:07 PM
RSM93HONDA
Ok turned out timing belt slipped due to a bunch of plastic from the timing cover be cut off by the belts. the timing was off 40 degrees. The plastic got on the gears under the cover and caused the belt to slip. The car starts right up and runs better than it did. Thanks to all that contributed. Thanks.
1993 Accord SE
RE: Timing Belt? spark plug test - 2/26/2007 10:12:36 PM
rchnsgl
need the timing marks for the small belt used along with the main timing belt on the 1991 Honda Accord. I dont have any marks on the smaller belts which appear to run the oil pump and the harmonic balancer. The balancer puller has what looks like a punch mark on one of the teeth but I cant locate a stationary reference mark on it. Can anyone give me some guidance on the marks to fully time this engine. Thanks, Rchnsgl
RE: Timing Belt? spark plug test - 2/26/2007 10:27:58 PM
TexasHonda
quote:
ORIGINAL: rchnsgl need the timing marks for the small belt used along with the main timing belt on the 1991 Honda Accord. I dont have any marks on the smaller belts which appear to run the oil pump and the harmonic balancer. The balancer puller has what looks like a punch mark on one of the teeth but I cant locate a stationary reference mark on it. Can anyone give me some guidance on the marks to fully time this engine. Thanks, Rchnsgl Post a new thread. You'll get better responses to your problem. good luck
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
