RE: Battery/alternator issue
Login | |
RE: Battery/alternator issue - 2/25/2007 2:46:25 PM
jewlow5
Alright, update time. So I disconnected the battery yesterday and let it sit overnight. I just got back inside from trying to start it, and this is what happened when I checked on it this morning.... I went out to the car, reconnected it, made sure everything was clean and on securely, got in my car and turned the car on ( did not try to start it right away) the dash lights came on, but when I tried to start it, power quickly drained...the inside light was dim and within about 10 minutes of letting the car sit the dash lights became nearly completely off, very hard to see that they were lit... so im thinkin just a bad battery... am I correct?? thanks for all the help!
RE: Battery/alternator issue - 2/26/2007 12:11:42 PM
brayner
probably. at this point I would take it back where you bought it and have it tested. Bad batteries from the factory are not that rare.
_____________________________
94 Accord EX wagon 4-cyl VTEC F22B1 auto
RE: Battery/alternator issue - 2/27/2007 2:31:33 PM
YeuEmMaiMai
first off load test the system BEFORE you do anything. That will tell you where the problem is......
Jesus is Salvation White 2002 Acura CL type S. 68K and change Criminals thrive upon the intolerence of society''s understanding.....and political correctness
RE: Battery/alternator issue - 2/27/2007 3:44:33 PM
deserthonda
you are going round and round asnd getting nowhere..... have the battery properly CHARGED and tested .. also have the CHARGING SYSTEM properly tested.. and make sure that they test for electrical drain.. DO ALL THESE AND LET US KNOW before you seek more advices
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: Battery/alternator issue - 2/27/2007 6:28:11 PM
RTexasF
Forum Monitor Posts: 2357
Joined: 11/16/2004 From: Brownsville, TX Status: offline
Agreed. You've asked for advice, taken none, and continue to ask the same questions over and over. Heed the advice and tell us how it worked out or buy some new shoes for walking.
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: Battery/alternator issue - 2/28/2007 12:28:48 AM
JimBlake
quote:
ORIGINAL: jewlow5 Well, I got it jumped this morning, and its disconnected right now. Were the jumper cables connected long enough to charge it? If not, you haven't proven anything. Get the battery checked out. If you don't measure it properly, that won't be a good substitute. Do you have a multi-meter? If so, you can do a reasonable job of checking it out. But only if you make proper measurements & interpret them correctly. If you don't have a meter, then you'll just be guessing.
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
