RE: 1990 unfinished project. odd idle @ all rpm's
  Printable Version
Honda Accord Forum >> General >> General Tech Help >> RE: 1990 unfinished project. odd idle @ all rpm's Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 6:40:11 PM
ericschillin
Status: offline
ok, here goes. i put on the new cap, rotor, plugs, and wires. there was oil all over the middle of the plugs. not the tops, and not the spark part, but everywhere else. quite a bit. that didnt help. than i bleed the air in the system at the thermostate like told, and that didnt help. after that i took off the intake and it looked like the throttle paddle thing inside the body, was sticking. so i thought, adjusted that and still no luck. after that i reset my iacv as directed, and still no luck. so i drive it around the block, and the major problem seems to be that the when the cars in gear, it idles high and holdes high. when it idels in nutural its fine. sound a little shakey maybe. maybe not. but it stays at about 800. its when i try to drive it, it starts the automatic reving on its own. anotehr thing i wondered, was when i took off the intake, there was a hole in the inside back of the throttlebody, that had a huge vacume on it when i gave it gas. is that hole supposed to be so loud it sounds like a tiny turbo. it makes a kinda loud whip noise. hard to explain. also, there's a tube that comes off the gear box(i guess its called) where the shifter and cluch cables attach to tranny to shift it, its just sitting there and it blows some sort of fluid on the intake after time. other than that, maybe its the distributor. myabe something cheaper i hope. i hope i didnt buy a lemon. feedback? thanks, eric
(in reply to JimBlake)
Post #: 16
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 8:23:07 PM
JimBlake
Status: offline
Oil in spark plugs...
There's round seals (part of valve cover gasket) that can leak oil down into the sparkplug tubes.  I think there's a DIY about this over in the DIY forum.
It's possible that your IACV has gone bad, not just dirty.  Sometimes they do that...
Throttle plate was sticking, you fixed it, good.
Check out hondaautomotiveparts.com, put in your car's info, look at the parts pictures.  You want to verify that all your vacuum hoses and water hoses are going where they should.  Check out...
intake manifold
throttle body
water hoses
Here's throttlebody.  Check/cleanout the fast-idle valve #8.  That whistling hole supplies air to your IACV (#15) and your FITV (#8).  One or the other isn't closing like it should.
Find the idle adjustment screw (#1).  If you can't find it, maybe it's MIA and that's the hole you're talking about??
I'll have to see what that tranny vent line is all about.  Trannys have air vents, but they're not supposed to dump fluid out.  Here's the tranny case, I think #5 is a rubber cap on the vent tube.
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to ericschillin)
Post #: 17
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 8:44:29 PM
ericschillin
Status: offline
yeah, i thought maybe the FITV was bad or something. cuase thats where the noice was comming from. so i guess i can take it off and clean it. it looked like the screws where comming from the inside, and its about 3 inches from teh firewall, so getting to it that way will be hard. i need to take a better look tomorrow. the idel adjustment screw, if its what i think it is(next to the three vaccume lines that go into the intake), i tired to turn it today, and did so succefully, but the idel didnt go down, or so it didnt seem to.(did it when i disconnected teh IACV to reset it) but when i disconnected it, the engine's idle kept going up and down, up and down, and so on. so maybe it did work. or is it on the inside of the throttle body? cant tell by the pic. and yeah, thats teh tube on the tranny, looks like all it needs is a plug. sould i be worried if oil leaked into where the spark plugs go when i swiched them? it ran fine for a while after i did all these tricks of the trade today. thanks, Eric
Post #: 18
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 9:06:34 PM
ericschillin
Status: offline
so basicly the FITV going bad or being dirty can cause this problem? do that tomorrow, atleast.
Post #: 19
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 9:08:34 PM
ericschillin
Status: offline
Post #: 20
RE: 1990 unfinished project. odd idle @ all rpm's - 3/13/2007 9:49:57 PM
ericschillin
Status: offline
i somehow ended up with two seperate forums. so basicly i reset the ecu today, bleed air from coolant, new plugs, rotor, cap, wires, cleaned iacv other day, all to no success. next going to check the FITV, do these commonly need replacing?  if so if i can get one for  about $10, should i just replace it, or if it isnt broke, dont fix it?
Post #: 21
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 12:16:22 AM
JimBlake
Status: offline
Some folks have had success taking the FITV apart, cleaning & tightening it.  Under the round cover there's something that works loose.  I'm vague because this problem hasn't happened on my cars.  Search for a thread with pictures about doing this.  Any one of these components might be bad enough that cleaning won't fix it.
Between all this and the leaking sparkplug seals, you have several things happening.  It's gonna seem like nothing helps until it's ALL fixed up.  But don't despair, you're making it better with everything you clean up.
All that stuff works together to control idle, and if 2 or 3 things are dirty/clogged/broken, then the entire system gets unstable.  On top of that, your oily sparkplugs can cause misfiring to further confuse the system.
IACV is supposed to adjust itself to stabilize the idle, controlled by the ECU.  It doesn't have wide range to provide fast-idle when the engine is cold.
FITV is supposed to open when cold, to provide fast-idle.  Then close completely.  This is simply based on temperature of the coolant running thru it.
There's also that other air valve #9.  I'm not really sure what it does.
PS:
That rubber cap on the tranny vent is NOT airtight.  There's a passageway for air, facing downwards.  Hard to explain...  But don't plug the tube or you might start blowing driveshaft seals.
< Message edited by JimBlake -- 3/14/2007 12:20:09 AM >
Post #: 22
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 12:40:06 AM
PAhonda
Status: offline
Here is a link with some pics on how to fix the FITV.  That plunger needs to be removed, cleaned, then screwed all the way back in the valve body.
http://honda-tech.com/zerothread?id=699787
1995 Accord EX MT
Post #: 23
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 2:00:51 AM
ericschillin
Status: offline
well its about 2am, and i just got done cleaning the FITV. i cant start the car cause i'll wake the neighbors. but i noticed wheni took it off and apart, that there is a inner plastic peice that i unscrewed to take it apart(inside #8), and after a few turns, i thought to see where it was before i moved it. well it was too late so i just tightened it up all the way when i put it back together, which i'm pretty sure its supposed to be. and hope it works. i wonder if that adjustment has anything to do with it. like how much i tighten that inner peice. cause there's a spring inside teh lower part of the  FITV that goes up and down with the inner plastic peice  in the upper part of the FITV when i adjust it. so i'm going to start her up tomorrow with it all the wait tightened, and turn her off, adjust a little, turn back on.. and keep doing that till i fix it, or things get worse and i put them back.  also, if you look at the top diagram a few post back,  #6 is the throttle body, i was concerned about the peice on the left side of it(opposite of throttle lever?)  its right outside where the two holes inside the throttle body that the loud noise was comming from when i give it gas.
Post #: 24
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 2:06:47 AM
ericschillin
Status: offline
i just saw your link to the FITV cleaning process. would of made my last post easier to explain if i knew you had posted that. the white peice is what i was talking about adjusting. i just tightened it all the way down. thanks for all your help by the way, i really appreciate it.
Post #: 25
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 2:08:25 AM
ericschillin
Status: offline
Everyone's Help.
Post #: 26
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 2:15:47 AM
PAhonda
Status: offline
No problem.  You did it correctly, it should be tightened all the way down.  Was that plunger all the way down when you took the FITV apart?
1995 Accord EX MT
Post #: 27
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 8:19:55 AM
JimBlake
Status: offline
quote:
ORIGINAL: ericschillin
...  #6 is the throttle body, i was concerned about the peice on the left side of it(opposite of throttle lever?)  its right outside where the two holes inside the throttle body that the loud noise was comming from when i give it gas.
That thing opposite the throttle pulley is the throttle-position sensor (TPS).  It isn't related to those holes.  The holes basically just connect back to the IACV & FITV.  If your FITV was very loose inside, that's probably a large part of the problem.
Post #: 28
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 12:33:25 PM
ericschillin
Status: offline
i'm not sure if the white peice was all the way down , but i think it was pretty darn close when i took it apart. well i just started my car and drove her around the block twice, than took her on the main road for a to see what she had. well she drives about 5 times better than she did before last nite.  last nite i took the FITV apart and also got down and dirty with cleaning the inside of the throttle body better. she still seems to be sticking  just a little bit, or should i say the rpm's are still staying up for a short second after i left off the throttle. the rpm's dont stay rev'd up as long, but it's still doing it enough.  she still seems to be sluggish too till the higher rpm's when i took her on the main road. deffinitly the first improvment since i've started on this project. without a doubt she drives better than i've ever seen her drive since i've had her. we're getting there. Eric
Post #: 29
RE: 1990 unfinished project. odd idle @ all rpm's - 3/14/2007 12:39:24 PM
ericschillin
Status: offline
how much should the throttle be open when the car is idle'ng. it looks like its completley closed when i dont touch the throttle. eventully i'll learn all the technical terms, but the peice inside the throttle body that opens and closes.... should that be open at all ? cause mine looks pretty much closed all the way.
Post #: 30
Honda Accord >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
