RE: More Problems after Time Belt Change and etc..
  Printable Version
Honda Accord Forum >> Your Ride >> Engine & Internal >> RE: More Problems after Time Belt Change and etc.. Page: <<   < prev  1 [2]
Login
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 12:04:53 AM
RoKnAzn
Status: offline
Its a good amount that leaks out...So I will investigate some more...
_____________________________
1993 Honda Accord EX 5speed (DD for Now)
2000 Jeep Wrangler SE Auto RockCrawler (Under Construction)
2002 Chevy Avalanche Auto 2wd (Mom's DD/My Tow Rig)
2005 Toyota Corolla S Auto (Dad's DD)
2007 Honda Civic SI 6speed (Brother New Car)
(in reply to JimBlake)
Post #: 16
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 12:55:33 PM
sir_nasty
Status: offline
does your interior smell like anti-freeze at all or just water?  does the carpet feel "squishy" when you push it down like it's soaking wet? has it rained a lot recently?
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''''s great but it''''s not all beer and skittles
(in reply to RoKnAzn)
Post #: 17
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 2:41:04 PM
RoKnAzn
Status: offline
Yes, but barely noticeable. The passanger side is more squishy, then the driver side. Both side Leaks..It has not rained recently..
Thanks
Anthony
(in reply to sir_nasty)
Post #: 18
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 5:24:09 PM
JimBlake
Status: offline
Soggy underneath the carpeting, that would take months to dry out.  So maybe it leaked in there a long time ago.  Look for disconnected sunroof drains, missing plugs in the firewall, bad weatherstripping around the doors, anything like that??
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 19
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 5:46:03 PM
RoKnAzn
Status: offline
quote:
ORIGINAL: JimBlake
This is due to the Cooling system of the Car. Since I still have to add a good bit a water...:P
Post #: 20
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 7:44:13 PM
sir_nasty
Status: offline
It sounds like a bad heater core.... without going back and re-reading the notes was that mentioned or checked already?
Post #: 21
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 9:38:10 PM
RoKnAzn
Status: offline
I believe so too...I pulled the carpet on the passanger side and it was soaking wet. I also touch the tunnel and it was wet. So I think that is it. I just called Advance Auto Parts and order one for 57 Bucks from Rad-Flow. How hard is it to remove the Heater Core?
Thanks
Anthony
Post #: 22
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 11:19:54 PM
deserthonda
Status: offline
quote:
ORIGINAL: RoKnAzn
I. How hard is it to remove the Heater Core?
Thanks
Anthony
before you replace the heater core make EXTRA sure that is what is leaking ,, cause,, it is NOT an easy job to replace it ,, the complete dash has to come off ,, I would suggest you buy an HELM book if you plan on doing it yourself ,, or download an online manual with all the details ..
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 23
RE: More Problems after Time Belt Change and etc.. - 3/27/2007 11:25:07 PM
RoKnAzn
Status: offline
quote:
ORIGINAL: deserthonda
quote:
ORIGINAL: RoKnAzn
Thanks
Anthony
That is the only thing that can leak inside the Honda unless Im mistaking.. I have the Haynes Manual and it looks pretty simple. Just wanted to be prepare for the removal and install..
Thanks
Anthony
BTW. Where can I download the Online Manual?
< Message edited by RoKnAzn -- 3/27/2007 11:26:56 PM >
(in reply to deserthonda)
Post #: 24
RE: More Problems after Time Belt Change and etc.. - 3/28/2007 12:35:57 AM
JimBlake
Status: offline
Heater core would be the only place for antifreeze to come from, & get under the carpeting.  Are you sure it's antifreeze?  By the smell?
It seems to me that if the heater core were leaking, it would fog up the windows something fierce.
Like desert says, it's a big job.  Make sure that's really the problem.
Post #: 25
RE: More Problems after Time Belt Change and etc.. - 3/28/2007 10:30:42 AM
RoKnAzn
Status: offline
quote:
ORIGINAL: JimBlake
Well, Before I start putting water instead. I have a Blue Spots on the carpet. So yes, 95% sure of it. I always drive with the windows down. Plus A/c dont work no more (need to fix)..:(
Post #: 26
Honda Accord Forums >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134309
00accordlx5s3815
deserthonda3575
live2rice3459
jimblake3285
19accord973171
smaglik2623
New Vendors
Sportwing
