RE: Shifting with an automatic....
  Printable Version
Honda Accord Forums >> Your Ride >> Engine & Internal >> RE: Shifting with an automatic.... Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Shifting with an automatic.... - 4/13/2007 5:09:08 PM
legionofone
Status: offline
tiptronic, autostick, paddle shift, slapstick,
(in reply to marbro)
Post #: 31
RE: Shifting with an automatic.... - 4/13/2007 5:30:51 PM
sssexy70
Status: offline
I didn't say anything opposing that, all i was saying is that with an automatic, it'll shift fastest if you just pop it into drive rather than trying to control it no matter what system you have.  But the tip-tronic whatever is quicker than going from 1 to 2 to d3 to d4 because they are different types of systems
Post #: 32
RE: Shifting with an automatic.... - 4/13/2007 5:55:51 PM
marbro
Status: offline
depending on the system it should be the same between all those.   When i get bored and do 1 through d4 each click it shifts at the rpm point that im at.   The only time it doesnt is if i have the foot to the floor and shift 4.5k rpms from second to third then the computer realizes its at WOT then shifts back to second.   Either way, auto's have improve greatly over the years
(in reply to sssexy70)
Post #: 33
RE: Shifting with an automatic.... - 4/13/2007 7:02:35 PM
sssexy70
Status: offline
Sorry, should have been more specific in the fact that i'm talking about full throttle acceleration... 03 Sleeper was talking about timing his automatic to a manual... i was just saying that shifting yourself in a race will slow you down in an automatic
Post #: 34
RE: Shifting with an automatic.... - 4/14/2007 12:21:25 PM
deserthonda
Status: offline
quote:
ORIGINAL: marbro
im not sure... but i dont think shifting into park would ruin the transmission       putting it into park for the transmission is the same as putting it into N  its just park also has the whole wheel lock thing.
a couple of things i can throw in here,,
# 1 .. it is ok to upshift or down shift an auto tranny manually , it is no big deal ..the only thing is, especially when downshifting to make sure you do it at the correct speed ,, if you are going at 70 you surely would not want to downshift to second or first gear .. REDLINE possible engine damage .. but especially if you are going in a steep downhill or uphill , you can downshit the tranny and leave it on the gear so tranny does not go back and forth up and downshifting ,, and on a steep downhill, you would not have to use the brakes so much if you shift it into lower gears
# 2 ,,DO NOT for any reason sfift the auto tranny to PARK while driving.even at 10 mph . there is a parking pin which engages in the parking gear ( so car does not roll when in park ) that can, and i have seen shatter when tranny is put into park while driving .. and yes you do have to remove the tranny and basically overhaul it,, you cannot leave any metal inside a Honda auto tranny , it will seize up the valves in the valve body faster than you can say BOO .fluid will carry and metal filing all over the inside of that tranny ...Putting in neutral will not do any damage except depending on the speed you are going rpm would shoot way up ( redline ) unless you take your foot off the accell .
But again as for shifting under normal driving condition ,, it is perfectly safe
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 35
RE: Shifting with an automatic.... - 4/14/2007 1:21:23 PM
marbro
Status: offline
ah, so the parking pin is inside the trany, I thought it was something outside that locked
(in reply to deserthonda)
Post #: 36
RE: Shifting with an automatic.... - 4/14/2007 1:36:14 PM
sssexy70
Status: offline
Thank you for clearing that all up Desert!  We can always rely on you to settle an argument!
Post #: 37
RE: Shifting with an automatic.... - 4/14/2007 3:33:43 PM
03Sleeper
Status: offline
03Sleeper's photo gallery
I learned a lot from this thread. w00t!
2003 Accord LX Sedan I4| 5AT 101045
Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
Post #: 38
RE: Shifting with an automatic.... - 8/1/2007 8:54:14 PM
harold6091
Status: offline
the worst thing you can do its to shift it with auto i mean you can do it a couple of times like i do but it aint good thats why auto trans car are for old people(not designed for teenagers)
(in reply to 00AccordLX5spd)
Post #: 39
RE: Shifting with an automatic.... - 8/2/2007 8:05:17 AM
PhotoJim
Status: offline
quote:
ORIGINAL: 03Sleeper
then whats the hype about manuals? I have a 5 speed automatic...which is the same amount of gears as most manuals.
1.  Manuals cost significantly less than automatics (often over $1,000 less).
2.  Manuals are more fun to drive once you know what you're doing.
3.  Manuals usually get better fuel economy, particularly in the city.
4.  Manuals permit faster acceleration because you have more control over when the transmission shifts.
5.  Manuals are simpler and thus more reliable, and also less expensive to repair when they do fail.
6.  Manuals weigh significantly less than automatics.
7.  Manuals give you more control over torque and traction (e.g. starting in second gear during slippery weather).
8.  Most car thieves can't drive manual transmissions, so it is less likely that your car will be stolen.
Technology that thinks for you is great - as long as it does exactly what you want it to do when you want to do it.  I've yet to find an automatic transmission that performs precisely as I want it to perform, so I buy manual-equipped cars instead.  I pocket the savings, get more enjoyment and get better performance.
Jim
2007 Honda Accord EX-L I-4 5MT
2009 Honda Fit Sport 5MT
(in reply to 03Sleeper)
Post #: 40
RE: Shifting with an automatic.... - 8/2/2007 11:42:15 AM
KevinAccord
Status: offline
hey, this post was very helpful... thanxs guys...
2000 Accord LX i4 Turbo AT
18" Konig Unknown Rims
MSD 6AL
Gold Line Suspension
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
Post #: 41
RE: Shifting with an automatic.... - 8/2/2007 8:11:29 PM
03Sleeper
Status: offline
Way to resurrect a dead thread.
(in reply to KevinAccord)
Post #: 42
RE: Shifting with an automatic.... - 8/22/2007 10:53:39 AM
falkore24
Status: offline
falkore24's photo gallery
Contrary to popular belief, I find that my launch is significantly better when shifted.  First gear on my car can fly, but when it's not in 1 it will shift out too soon.  Also, engine braking adds control when done right.  The biggest thing that you have to learn is where the car wants to shift in various conditions and how long it will take to initiate the shift.  If you floor it in 1 and wait until you want the car to shift to click it into 2 then you are going to bounce the rev limiter.  It needs about a third of a second.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 43
RE: Shifting with an automatic.... - 8/22/2007 11:21:32 PM
nafango2
Status: offline
dual clutch is where its at.
no torque converter.
you can use auto in the city.
manual when your having fun.
no user-operated clutch tho... not as fun.
granted... I hate howstuffworks as much as the next guy... but they did a decent job on this one: http://auto.howstuffworks.com/dual-clutch-transmission.htm
< Message edited by nafango2 -- 8/22/2007 11:24:03 PM >
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2)
Security System / Keyless entry
(in reply to falkore24)
Post #: 44
RE: Shifting with an automatic.... - 8/23/2007 7:59:57 AM
marbro
Status: offline
quote:
ORIGINAL: falkore24
Opinion is always contrary to popular belief when it doesnt follow it.   Which makes the comment rather pointless.   Now, if you said Contrary to popular belief these dyno's show it helps,    then that would be something,   now wouldnt it.
98' Accord project car/ Daily driver
Post #: 45
Honda Accord >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2648
smaglik2594
New Vendors
Sportwing
