RE: Timing Belt Job
Login | |
RE: Timing Belt Job - 5/10/2007 4:24:20 AM
mig25
I have the Belts part all together , I did not yet finished it all yet. I adjusted the valves, I will replace the oil Pan gasket and plugs etc.Today or tomorrow I will finish her up. I will let you know how does it run as soon as it is all back up.
_____________________________
1993 Accord 10th aniversary edition 2.2L Sedan Auto 1995 Civic DX Auto 1.5L D15B7 2 2005 Jettas TDi Pump Deuse ( Both Manual trans ) 52 MPG
RE: Timing Belt Job - 5/11/2007 5:59:09 AM
mig25
Yikes ! double post. Moderator please delete. Thanks
RE: Timing Belt Job - 5/14/2007 7:24:33 PM
mig25
It's Alive ! It's Alive ! Put it back together, started right up, run like a champ except that when it idles sometimes the engine hick ups, I couldn't figure out why
RE: Timing Belt Job - 5/15/2007 3:26:38 PM
Tony1M
Very good that it is running well except for that small problem. Did it hiccup occasionally before the work you did to it? Does it hiccup both when the engine is cold and also when it is hot? Just a suggestion - are the rotor, cap and plug wires original to the car? If so, when you had to pull the wires off the plugs, you may have inadvertently damaged one of them.
Tony 1992 Accord LX, 4AT, 4 dr, no AC, no power anything
RE: Timing Belt Job - 5/15/2007 3:29:59 PM
mig25
Tony, Everything is brand new, Rotor, Cap, wires, plugs. I have replaced the fast idle valve and cleaned the throttle body and replaced the gasket , also cleaned the EGR and replaced the gasket. Frickin hick up continues Only when it is warm , idling
< Message edited by mig25 -- 5/15/2007 3:30:33 PM >
RE: Timing Belt Job - 5/15/2007 3:58:59 PM
Tony1M
So it does not hiccup when it's cold - only when hot. Did it hiccup before you did all your work and replaced all those parts? If not, I'd first suspect one of the new parts is faulty. How did the old plugs look when you removed them - normal color for them all? A bad plug can sometimes work very well cold, but occasionally misfire when it's hot, and, although it is pretty rare, sometimes a new plug will be faulty and do that. If I were you, if there was no hiccup before the job, I'd first put the old cap, rotor, and plug wire harness back on the car. Start the car. If the hiccup is still there, do you still have any of your old plugs, or a spare new one? If so, replace one plug, start the car, and see if it still hiccups. If it does, repeat for all four plugs. If after doing that the car still hiccups, then I'd start to suspect that the valve adjustment may not be quite right, but in that case, I would expect a continuous problem, rather than in intermittent one. Let us know how you make out.
RE: Timing Belt Job - 5/15/2007 6:06:40 PM
mig25
Oh well, I have to take that back, the hick up happens when it is hot and cold , just tried it tonight. Just a piece of info I forgot to add, I have removed the distributor to replace the O ring. Tomorrow I will set the engine to TDC and check the distributor to make sure it is pointing to cylinder number One. Ok , I edited this post I checked the Timing this afternoon and it is Perfect. filled up her tank with premium $3.15 per gallon Dang !! But the hick up still goes on... I got a Set of Denso , I might buy a set of NGKs and try them out. Also I could not find the test terminal to hook up a Tach... Oh Well...
< Message edited by mig25 -- 5/16/2007 7:55:10 PM >
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
