RE: Bolts that hold front rotor problem
  Printable Version
Honda Accord >> Your Ride >> Suspension >> RE: Bolts that hold front rotor problem Page: <<   < prev  1 [2]
Login
RE: Bolts that hold front rotor problem - 4/20/2006 12:03:27 AM
sportsman1539
Status: offline
quote:
Mr 97 why are you concerned that those bolts ares tripped ?? are you planning on replacing the front rotors ?? if not do not worry about it.....if you are let me know i will tell you a little trick that it has worked for me in the past......
yea i wanna know this trick too. i was starting a brake job the other day and ran into this problem. the head was rounded off on one of the rotor to hub bolts. can rotors be turned with hub still attached? it seemed like i saw someone do this once.
(in reply to MR.97ACCORD)
Post #: 16
RE: Bolts that hold front rotor problem - 4/20/2006 1:52:09 PM
sleep depervation
Status: offline
sleep depervation's photo gallery
[/quote]
yes they can turn them on the car.....rotors
_____________________________
say night, night little sleeper.
I LOVE Danica!
(in reply to sportsman1539)
Post #: 17
RE: Bolts that hold front rotor problem - 4/21/2006 10:41:06 AM
deserthonda
Status: offline
quote:
ORIGINAL: MR.97ACCORD
tell me about the trick?
this has worked for me many times so i hope it will work for you..............
get a hammer and hit the head of the bolt making it flatter ( wider ) get a good socket if socket is worn this will not work , 6 point socket , DO NOT use a 12 point socket . if socket will not go over the bolt after you have hammered the bolt, hammer the socket into the bolt, the tighter the better grip it will have , get a breaker bar or impact wrench if available. and remove the bolt,
make sure that if you do use a breaker bar , it is straight , if it is not straight socket will slip out .. .........if you di it right , it should work for you as well..
Post #: 18
Honda Accord Forums >> Your Ride >> Suspension
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6840
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133279
jimblake3137
19accord973125
live2rice2648
smaglik2594
New Vendors
Sportwing
