RE: twin turbo help
  Printable Version
Honda Accord >> Your Ride >> Nitrous, Super Chargers, & Turbos >> RE: twin turbo help Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: twin turbo help - 11/28/2005 3:41:06 PM
Patrick
Status: offline
if youre going to build big, i would go with a well known aftermarket brand name like felpro...etc.
(in reply to 6thgen)
Post #: 16
RE: twin turbo help - 12/1/2005 11:03:12 AM
tcodi
Status: offline
If you're gonna push that must boost you are basically going to have to build a completely new motor (unless you only need it to last
one full throttle run).
Your rings aren't gonna hold under that much boost so they'll have to be replaced. If you replace rings you need to have the cylinders
machined. New rings in a glazed cylinder won't break in and it'll burn oil like no other, not to mention poor compression.
You'll need dished pistons to reduce compression, plus new heads with bigger combusion chambers to reduce it further. If you run 15psi
boost that basically doubles compression, so you'll need to be down at 5:1 static to run pump gas.
You'll probably want a closer ratio of exhaust valve to intake valve size with that much boost too, and more exhaust duration.
If you don't intercool a 15-20psi charge it is a waste of time, so you'll need that too.
The crank and rods will have to go.
Plus all the little stuff like injectors and intake and whatnot.
Basically you're gonna have to build a completely new engine from a bare block to do this.
I'd consider this expert level work.
(in reply to Patrick)
Post #: 17
RE: twin turbo help - 2/28/2006 8:28:55 PM
flomasta
Status: offline
Okay, I really wanna turbo it. it's an auto but i sill wanna do it cuz i heard that forced autos can be quicker than boosted sticks. i don't have much money now and wont at least till summer. should i buy a kit or should i buy a turbo i want and custom pipe it. i also heard that people are taken turbo set ups from eclipses in salvage yards. Is that worth doing, what kinda power could you expect from doin that and how easy of an install is it?
(in reply to tcodi)
Post #: 18
RE: twin turbo help - 3/1/2006 12:19:52 AM
lightshow
Status: offline
turbos are not easy...if you have been following the turbo help post its pretty easy to see how many little things can make a big difference.. and mbo is obviously a great mechanic. i also think your eyes are getting a little bit bigger than your stomach right now.. you should keep it realistic. you not going to have 5-8 thousand dollars and another car to drive around for 3-4 months anytime soon right? have you ever been in a 200 hp turbocharged honda? its seriously a mean bitch your adrenaline just skyrockets as soon as the turbo spools. there is a list of everything you need to turbo your honda in the turbo help post. and it should cost you anywhere from 600-1400 dollars, and if you get all that stuff you can even take it to a shop and they should be able to install it in about 10 hours....and they will charge you 70 or 80 dollars an hour. so i mean a couple g's or less and you have a real live turbo. the turbo off a 2g eclipse is good for about 275 hp, and your motor can easily hold 200-225 with your tranny. i would seriously recommend parts off eclipse's because they are cost efficient. i seriously want to see more people like mbo who are actually doing the real thing and not just dreaming...yea everyone wants to have a 400 hp car, but when cost and time IS a factor it can completely stop you from doing a hellava good project like this if your head is in the clouds. you should be looking for the first piece to the puzzle right NOW. with your next couple of paychecks get a turbo for 200 bucks or 100 bucks. once you buy it....you have a turbo, the momentum is started......your going in a great direction at that point..then.....get an fmu....80 bucks....manifold.... intercooler...external wastegate if you going to use one... syanpse....emanage....shit even those 5 check valves if you want to go ghetto.. pile up the parts...and then you can decide whetheror not your able to do the install, or your going to have someone else do it. there are obviously alot of people on here that know a LOT about turbo and i would also be happy to help
(in reply to flomasta)
Post #: 19
RE: twin turbo help - 3/1/2006 9:10:06 AM
mbo1985
Status: offline
Lightshow has got it right. Keep your goals realistic. Why not piece together a kit that will give you flexibility down the road to really turn up the boost, while in the meantime, will still give your car some mean boost.
And trust me, 8 psi in your f22b2 (same motor as I have. I freshly turbo'ed mine) is going to slam you back in your seat and bring a childish smile to your face. When i hit the boost i feel like i'm in my friend's mustang GT.
There's nothing wrong with shooting for 300 hp (that's my goal too), but why not start off small first. And while you run 8 psi, you can be building a turbo f22b2 motor so you can really turn up the boost. The f22b2 (your car's motor) can be had for cheap compared to the H series.
I'm not sure if anyone has pointed this out yet, but your auto tranny will need a look at too before you put 300 ponies to it.
(in reply to lightshow)
Post #: 20
RE: twin turbo help - 3/1/2006 1:43:57 PM
flomasta
Status: offline
Thank you for posting helpful info for me. i know that i must start small and can't get 300 horses off just a turbo, i'm above that level of knowledge. I also know that the tranny, and various other parts of the engine and drive train will need to be addressed in order to cope with the added power. I was simply wanting to know what a good set up is to help me on my way to my goal. i'm not sayin just the turbo will put me up there, and it's not easy to do. when i asked how easy of an instal was involved i meant as far as custom fab work went
(in reply to mbo1985)
Post #: 21
RE: twin turbo help - 3/1/2006 1:57:50 PM
lightshow
Status: offline
if your a good mechanic then i would do the exact setup that mbo just did and i would have a exhaust shop fab the intake and exhaust plumbing. thats cause i am a crappy welder (im always dipping the tip of the tig into the puddle :( )
Post #: 22
RE: twin turbo help - 3/1/2006 8:34:57 PM
flomasta
Status: offline
I'm pretty sure i could handle doing everything untill it comes to the welding, never done it on anything that has some sort of function to it. What kind of shops will do that for me. out here in Overland park Kansas there arnt any car shops outside of basic repair places that i have found.
Post #: 23
RE: twin turbo help - 3/2/2006 2:43:29 AM
lightshow
Status: offline
a muffler shop will
Post #: 24
RE: twin turbo help - 3/2/2006 12:08:13 PM
flomasta
Status: offline
like midas??
Post #: 25
RE: twin turbo help - 3/2/2006 12:21:12 PM
flomasta
Status: offline
Also what years of eclipses could i snag some parts from??
Post #: 26
RE: twin turbo help - 3/2/2006 8:14:00 PM
marbro
Status: offline
i believe any gsr 90 to 95
Post #: 27
RE: twin turbo help - 3/3/2006 12:13:55 PM
flomasta
Status: offline
okay what parts could i use besides the turbo? any of the piping or intercoolers?
(in reply to marbro)
Post #: 28
RE: twin turbo help - 3/3/2006 6:40:30 PM
marbro
Status: offline
i think you would need modification on the piping, im not sure how different the front end and turbo manifold are.... and for the innercooler it depends on what size of pipe you plan on running.
Post #: 29
RE: twin turbo help - 3/6/2006 2:17:59 AM
lightshow
Status: offline
- turbo
a great turbo to get is a second generation mitsubishi eclipse turbo/ T3-T4 garret/airresearch
-wastegate
turbonetics deltagate with a 7psi spring
-manifold
can be purchased or custom made at the shop. a simple log style manifold can work very well and is the cheapest. a tubular manifold is more efficient and costs a little more
-intercooler
can also be taken off a mits eclipse but a slightly larger front mount intercooler would work best.
-blow off valve
hks or other quality brand
-boost dependant FMU (fuel pressure regulator)
vortech FMU
-manifold pressure bleeder
synapse missing link
-high volume fuel pump
walbro 255lph
just get these parts and you will be set. the plumbing for the intake and exhaust can be done at a shop real cheap. turbo and manifold can be procured from a 2g or second generation eclipse. everything else you will want to buy separate.
Post #: 30
Honda Accord Forum >> Your Ride >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6763
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2403
New Vendors
Sportwing
