RE: twin turbo help
Login | |
RE: twin turbo help - 3/23/2006 5:29:08 AM
lightshow
the turbo will sit lower than that line. its the compressor that will get in the way. why im saying dont worry about the fitment, is because you want to be able to choose the location/direction of the turbo and then have a custom flange made.
RE: twin turbo help - 4/26/2006 9:59:56 AM
mbo1985
I ended up sawing my AEM v2 intake into pieces to relocate the air filter (which would have been right off the turbo) away from the engine. So you could do that. As far as selling it, no one will want to pay a whole lot for a cosmetically damaged one, even if it works fine. True, performance probably isn't effected, but don't expect to get much for it if it looks bad. Maybe you're better off saving it and hack sawing it, heh.
RE: twin turbo help - 4/26/2006 10:47:04 PM
legionofone
hmmm manual swap anyone?
RE: twin turbo help - 4/27/2006 2:02:16 AM
marbro
what about a manual swap?
RE: twin turbo help - 4/27/2006 7:57:15 AM
flomasta
i thought about it and wasn't sure if it would be worth it to go that route or to drop in a high stall tourqe converter... hmmmmmm.... so many choices...
RE: twin turbo help - 4/27/2006 1:30:40 PM
marbro
I think the manual would be better in general because of the shorter gear ratios vs an auto more power man, more power! ^_^
RE: twin turbo help - 4/27/2006 3:49:38 PM
flomasta
yeah i'm deffinatly into more power... lol but since i want to turbo it, should i switch it to stick first or does it matter?
RE: twin turbo help - 4/27/2006 4:01:10 PM
marbro
doesnt really matter in the end, both require research if youre going to do it yourself and both require a lot of money to have someone else to do it ^_- but turbo first, will be easier to install
RE: twin turbo help - 4/27/2006 10:54:04 PM
legionofone
hehe all depends on ur tastes... i love my manual because i slam almost all my power strait to the ground... ur loosing power out of ur turbo if u push the power out threw automatic....
RE: twin turbo help - 4/28/2006 3:49:38 AM
marbro
you lose power out of a turbo just from the fact the cars a vtec, any way you look at it, you can either goto a turbo first, get use to that, then put the standard on, have even more power, or just get a slight gain from doing the swap, then add the turbo and have a crazy amount of power that you most likely wont be able to handle, equal stages vs drastic changes are better usually ^_-
RE: twin turbo help - 4/28/2006 7:56:27 AM
flomasta
alright i've decided to get the turbo first. btw my cars isnt v-tec... i don' t know weather to be happy or sad about it... pro's and con's i guess. lol anyways i'm hearing alot about something called a hondata... sumthing or another... and it goes with turbos. i know its a computer but whats it for?
< Message edited by flomasta -- 4/28/2006 7:57:23 AM >
RE: twin turbo help - 4/28/2006 6:40:45 PM
tom15425
Hondata allows you to tune your car's air/fuel ratios, adjust your vtec, rev limiter and speed governor, boost and nitrous control, and basically anything you'd want to control. It's really nice for boost because it can sense up to 11lbs on the basic models they have (more if you get a better MAP sensor), whereas your stock ECU can't read over like 1lb. It also protects you from potentially destroying your engine by exceeding what your fuel system or engine can handle. Well, looking into I found a pretty informative page on their site. They can explain it better than I can: http://hondata.com/featuresboost.html
< Message edited by tom15425 -- 4/28/2006 6:42:35 PM >
RE: twin turbo help - 4/28/2006 7:43:51 PM
marbro
Stock should be able to read about 2 - 3psi, the reason i say this is because if your going 100 miles an hour i think thats around 2 psi depending on how your intake is setup ie ram air style intake but yes, after market ecu's are very important because other then the fact it evens everything out, it helps with the deficiencies of the stock ecu.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
