RE: Problems With My Car...
Login | |
RE: Problems With My Car... - 10/29/2007 9:57:57 AM
falkore24
Score: 0 Joined: 8/16/2007 From: Wayne, NJ Status: offline
Search HAF for threads about speedometer problems and ignition coils. Then when the mechanic tells you what he thinks the problem is, you have a good knowledge base to agree, disagree or suggest that he check something that may be related. If nothing else, the research will help you to not get frustrated by a problem that doesn't seem to make sense. As mentioned, this seems like a coil issue. Either type is not hard to replace and regardless, the cap, rotor, wires and plugs should be changed at the same time, so there is no additional work even if it is internal.
RE: Problems With My Car... - 10/29/2007 2:17:05 PM
9accord7
Score: 0 Joined: 10/23/2007 Status: offline
no... the engine is fine, though sometimes i hear a clicking coming from inside the dash (very faint sound though...) I think it has something to do with the little plastic gears that control the needle...
RE: Problems With My Car... - 10/29/2007 3:04:13 PM
falkore24
It's definately possible, there are posts on here for faulty speedo's and I believe that there are some recalls and TSB's on the topic. Try searching for your problem ...... car info would help too.
_____________________________
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: Problems With My Car... - 10/29/2007 3:10:21 PM
falkore24
quote:
ORIGINAL: 00AccordLX5spd Oh yeah....4 doors always seemed to go over pretty well with the ladies with me! Easier access to the back seat Spoken like a married man with his first child on the way in a few days!!! You are so destined to turn into a dirty old man!!!!    .... & here's one for the ladies and your wife for you
RE: Problems With My Car... - 11/6/2007 6:34:51 AM
9accord7
ok... so i replaced the clutch, pressure plate and throwout bearing myself... with ONLY 1 screw-up... i skipped step 8 in the mechanics guide and didn't disconnect the speed sensor from the transmission! haha, so now its sitting in my glove compartment and my car is holding it current value because the miles arent increasing! haha... anyways, the orange wire (data) pulled out of the sensor itself, so that i can hood back up.. the yellow (power) broke back in the engine bay a little bit, but i can connect those again, but the black (ground) is nowhere to be seen, so what im thinking ill do is connect it to a bolt or something near the speed sensor, that way its grounded and it should work! btw, the ignition coil is on the same curcuit as the speedometer, but it goes to the tach first (and my tach never dies or gives out) so i've concluded that its the speed sensor, and im heading to the dealer to pick up a new one! oh, and my dad bought the OBD tester for his laptop, so we're gonna plug it in this weekend and find out what codes my car is throwing! (the check engine light is on, but all fluids are ok)
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
