RE: Turbo Help!!!
  Printable Version
Honda Accord Forum >> Your Ride >> Nitrous, Super Chargers, & Turbos >> RE: Turbo Help!!! Page: <<   < prev  4 5 [6] 7 8   next >   >>
Login
RE: Turbo Help!!! - 3/6/2006 7:51:15 AM
mbo1985
Status: offline
I might be cooking some hoses, but it seems to only last a short while, right after boosting. I know there is a lot more heat under the hood now and I need to address this. I want to heat wrap everything, and I am also considering venting the hood somehow (maybe buy a vented hood?). The oil feed and return lines are hooked up the way they're supposed to, I think. I haven't been leaking oil from them (at least I don't think so).
At first I thought i was smelling crankcase vapors or something from the boost blowing by the pistons, but I raced a 2004 mustang GT yesterday and things weren't too pretty for him heh heh. And as soon as i learn how to launch the car without tire spin all out through first, things will be really bad ass.
(in reply to lightshow)
Post #: 76
RE: Turbo Help!!! - 3/6/2006 12:26:31 PM
lightshow
Status: offline
you shouldnt be blowing anything by the rings.....they are actually quite good. they are not the weak point on your system and would probably handle 25 psi. if your oil return line is not a perfectly straight downward path to the oil pan, then oil will build up in the turbo and will spit out the seals...this mixed will all the raw fuel running through the system when you roll on the throttle will cause a smell that i would somewhat relate to what your smelling, and it would only happen after some hard boost..
hows it running now? is it still dying at wot? and hows the transition from vacuum to boost?
(in reply to mbo1985)
Post #: 77
RE: Turbo Help!!! - 3/6/2006 2:47:42 PM
mbo1985
Status: offline
it's not a perfectly straight path to the pan. It is generally a straight shot down, but the pipe hose has a slight curve in it since I kept it on the longer side. Hmm, I guess that could be it. Marbro also brought up that it might be the raw exhaust gases from my wastegate opening and venting under my hood.
Other than that smell, things are running fine. Transistions are excellent and WOT is AWESOME. As I said, my friend's poor V8 mustang yesterday ate some dirt of mine.
Post #: 78
RE: Turbo Help!!! - 3/6/2006 2:57:07 PM
sir_nasty
Status: offline
Any video yet? I want to see it move... Help us live the dream through you! *L*
Post #: 79
RE: Turbo Help!!! - 3/6/2006 3:03:56 PM
lightshow
Status: offline
yea i definately like marbros idea, because that exhaust is exiting right out in the engine compartment
(in reply to sir_nasty)
Post #: 80
RE: Turbo Help!!! - 3/6/2006 3:06:42 PM
lightshow
Status: offline
definately wrap that pipe that is coming out of the turbo, because it is right in front of the wastegate. so its running good huh?? alright ......let me know what settings you have the msd at right now as far as when it starts to retard the timing, and by how much per pound of boost.
Post #: 81
RE: Turbo Help!!! - 3/6/2006 3:11:59 PM
lightshow
Status: offline
yeai bet that burnt tire smell is that pipe getting so hot and that rubber boot next to the turbo giving off that smell. you dont want the oil return line to be on the long side though. you should shorten it so its the perfect length. hey and your a good welder.....you should weld a pipe that runs off the wastegate, and cut a nice little clean hole in the side of your side fender and have it exit flush with that...that would seriously be sick.
Post #: 82
RE: Turbo Help!!! - 3/6/2006 3:54:35 PM
mbo1985
Status: offline
hahah that would be sick. The funny part is I thought about doing that exact thing. When the wastegate opens up, just have it scream out of that hole. haha. Right now I just have a short dump tube going down, but I'm thinking I should do something like that now.
I'll shorten that oil line though. Maybe that will help things.
If you have those ignition tips you mentioned lightshow, I'm all ears!
Post #: 83
RE: Turbo Help!!! - 3/6/2006 9:54:38 PM
lightshow
Status: offline
yep it deals with your msd ignition. what are the current settings on that. like when it starts to retard the timing and by how much per pound of boost or ATM or BAR
Post #: 84
RE: Turbo Help!!! - 3/6/2006 10:25:44 PM
mbo1985
Status: offline
The start point is set to about 2.5 psi. Kinda a safety setting for trying things out I suppose. I have the fine tune knob (in car knob) around 1.5. I'm not sure if that second number is in psi... just the numbers on the control its self.
Post #: 85
RE: Turbo Help!!! - 3/6/2006 10:30:02 PM
lightshow
Status: offline
whats the range on the knob inside the car?
Post #: 86
RE: Turbo Help!!! - 3/6/2006 10:42:51 PM
lightshow
Status: offline
ok just got the specs. its 0-3 degrees per pound.. so i want you to start with making sure that the MSD vacuum line is the exact same source as the FMU is using. then set the dial on the unit under the hood at 3 degrees, and the dial inside at 0.5. start with this and you may still be able to throw on some more timing on top of this. your probably going to feel a startling difference...and you now have a lot of room to work with here so this is where the fine tuning will need to come in. you just dont want to have any detonation at all... when you get the boost controller, and you add on some more boost you may want to up the dial in the car to .75 or even one. now if you run higher octane fuel.....or get a better spark.....you can throw on more timing so just keep that in mind. let us know how it goes
Post #: 87
RE: Turbo Help!!! - 3/6/2006 11:04:10 PM
lightshow
Status: offline
also, that bomb that you toasted that mustang i bet he was feeling bad....this will help you lanch and corner alot better.
LSD
Post #: 88
RE: Turbo Help!!! - 3/6/2006 11:22:24 PM
lightshow
Status: offline
and it sounds like the motor is just about dialed in so some good injectors would be a good idea. the 450cc's would be perfect. but in general now as you go up in horsepower, you will want to use this formula
(horsepower * BSFC)/ (number of injectors * duty cycle)
the BSFC of an n/a engine is usually .5 and on a turbo engine it is .6 or greater.
so if the dial on your MSD inside the car is set at zero and your running 8 psi. your car had 140 hp stock and there is about 14 psi in one ATM or BAR. so for every PSI there is a 10 hp difference so with 8 psi you would have gained 80 hp (if the dial is set at zero). so you should be hovering around 220hp at the crank. so 220 * .6 is 132 and 4 injectors * 80 percent duty cycle or .8 is 3.2.....so your injectors should deliver 41.25 lb/hr and to change this to CC's just multiply by 10.5....so you would need at least 433 cc's.
Post #: 89
RE: Turbo Help!!! - 3/6/2006 11:23:03 PM
lightshow
Status: offline
that timing stuff is the exciting part...i hope your rippin right now.
Post #: 90
Honda Accord >> Your Ride >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6562
sir_nasty6303
falkore245003
00accordlx5s3741
deserthonda3536
19accord973078
jimblake2924
smaglik2515
rtexasf2336
finch132101
New Vendors
Sportwing
