need Suggestions for my suspension...
Login | |
need Suggestions for my suspension... - 5/26/2008 4:27:39 PM
ford
hey guys... ive been hearing squeeking sound when i drive over bumps with my car and i am pretty sure its my suspension system...im not really familiar with the suspensions systems that i need so here i am needing opinions/suggestions for my suspension system...im planning on changing all for suspensions... i have a tight budget($0-$200)...can you guys help me out with this... thanks..
_____________________________
1994 Honda Accord Ex Leather -F22B1 I4 SOHC VTEC -Automatic Transmission -Ebay Cat Back Exhaust Syst
RE: need Suggestions for my suspension... - 5/26/2008 10:24:17 PM
finch13
Squeeking makes me think bushings, if so, you might be able to get new ones presses in for $200, but I highly doubt it. Anything else is about $175 for springs, $400 for shocks, $200 for camber kits, plus the bushings I mentioned.
-> USE ME TO SEARCH HAF <- 1999 Accord LX F23A1 5MT
RE: need Suggestions for my suspension... - 5/26/2008 11:05:33 PM
xpieceofcralpx
when my car was squeaking ; turned out my front left shock blew out..check them, if any of your struts is covered with oil..
2002 Sedan F23A4 ULEV VTEC 5speed Black on Black AEM SRI Exedy OEM clutch Dropzone coilover sleeves Tokico Blues shocks
RE: need Suggestions for my suspension... - 5/27/2008 11:13:27 PM
finch13
anything over 1" drop needs a camber kit on the rear for sure. I had Eibach Pro-Kits and they got the front camber back to spec, but the rear camber was negative and they adjusted them as much as possible to get them close to spec. They were still off, but the amount was negligible for tire wear concerns. It really depends on how low you plan on going. Usually an inch or less you can reuse the stock shocks, anything more you're going to be paying the full shebang. If you're only looking to drop and play your cards right, DIY'ing the Eibach springs will get you lowered for $200, it did for me :-)
