panel stuck at door
  Printable Version
Honda Accord >> Other >> HAF Help & Suggestion Center >> panel stuck at door Page: [1]
Login
panel stuck at door - 5/1/2006 3:09:13 PM
tbopha
Status: offline
I've freed the panel around the inside edges, but something is holding the door by the handle. Whats holding it in and how do i free it up on a 99 accord.
Post #: 1
RE: panel stuck at door - 5/1/2006 3:15:13 PM
sir_nasty
Status: offline
I'm assuming that you either missed a screw underneath the armrest (goes through the armrest and looks as if it holds the armrest to the door but it doesn't...) or there is just a plastic clip there.... Most likely there is a screw that goes down inside the "hand hold" in the door and has a plastic piece in there that needs to be popped out then the screw removed... can you take some pictures if this doesn't work?
(in reply to tbopha)
Post #: 2
RE: panel stuck at door - 5/1/2006 3:48:29 PM
tbopha
Status: offline
I took some pics but the files are too big to send over this program. Do you have e-mail account beside this one. this one only allows 500k. My pics are 1m and greater.
(in reply to sir_nasty)
Post #: 3
RE: panel stuck at door - 5/1/2006 3:49:35 PM
sir_nasty
Status: offline
I just PM'd you my e-mail address go ahead and send them there...
Post #: 4
RE: panel stuck at door - 5/1/2006 3:50:28 PM
tbopha
Status: offline
arm rest screw is removed and screw by handle.
Post #: 5
RE: panel stuck at door - 5/1/2006 4:06:56 PM
sir_nasty
Status: offline
alright I'm guessing that your door handle is the hangup... what you need to do is pull that door handle out slightly and you'll notice two things, one there is a metal piece that goes into the handle (that opens the door) on the inside and is held in place by a clip, remove that and disconnect the power wires going to your door lock switch...
I'm almost positive that's what you're fighting...
Option 2: that door handle (with the power lock switch) will rotate slightly and slip through the door panel if you like... then lift the panel up/off while sliding it through.
Thumbnail Image
Thumbnail Image
Attachment (2)
Post #: 6
Page:   [1]
Honda Accord Forums >> Other >> HAF Help & Suggestion Center
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
