power windows
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests >> power windows Page: [1]
Login
power windows - 10/16/2007 1:44:19 AM
honda671
Score: 0
Status: offline
i have a 95 accord lx,the problem is my power windows-all 4(four) opening my windows are alright but when it comes to closing them boy! they are very slow to close...can anyone out there let me know whats up with my power windows...i tried lube the guide rails but still..please anyone help!!!
rodney
Post #: 1
RE: power windows - 10/16/2007 6:29:22 AM
falkore24
Score: 0
Status: offline
falkore24's photo gallery
clean the tracks, then lube them.  Alcohol, a sponge and paper towels.
(in reply to honda671)
Post #: 2
RE: power windows - 10/16/2007 11:37:48 AM
deserthonda
Score: 0
Status: offline
quote:
ORIGINAL: falkore24
if this does not help you might have to replace the run channels,
Another thing you can try is to move the run channel guides a bit apart,, need to remove the door panel to do so, but loosen up the 10mm bolt at bottom of guides and push them a bit toward frt of car ( frt guide )  and back ( rear guide )  this will give window a bit more play ..
DO NOT spread them too much apart or window will go up a bit crooked  specially at top of tracks
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to falkore24)
Post #: 3
RE: power windows - 10/17/2007 3:01:30 AM
honda671
Score: 0
Status: offline
i will try out your advice and thank you
Post #: 4
RE: power windows - 10/17/2007 12:23:23 PM
falkore24
Score: 0
Status: offline
also, please post a signature and write smaller
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 5
RE: power windows - 10/18/2007 1:50:39 AM
honda671
Score: 0
Status: offline
the heck with you falkore i did not ask you or forced you to reply
**Please do not use any harsh words in the forums and >>Yes Please put your information in the signature section for everyone to see, it helps folks know what kind of car you have when they reply to any questions you have..**
< Message edited by WheelBrokerAng -- 10/18/2007 5:07:33 PM >
95 accord lx, 4cyl,5 speed manual,4door,f22b22
Post #: 6
RE: power windows - 10/18/2007 4:42:21 AM
falkore24
Score: 0
Status: offline
well that's uncalled for.
Post #: 7
RE: power windows - 10/18/2007 1:32:02 PM
19Accord97
Score: 0
Status: offline
19Accord97's photo gallery
quote:
ORIGINAL: honda671
the HECK**with you falkore i did not ask you or forced you to reply
Uhhh.... when you post a thread you are asking everyone to reply.
Totally uncalled for, and if that is how you will act on this forum when knowledgeable people are trying to help you, we would prefer you to leave or clean up your act.
< Message edited by WheelBrokerAng -- 10/18/2007 6:10:40 PM >
*Quit
Later
Post #: 8
RE: power windows - 10/19/2007 6:52:17 AM
white95
Score: 0
Status: offline
Since this guy is being a jackoff, I'm highjacking this thread...
My 95 LX has the same problem and the wipers run slow also.  I have cleaned the window tracks but I think the multiple motors running slow is related.  My little battery tester/charger says that the battery and alternator are fine, though I don't totally trust that.  Load detection was also tested in accordance (no pun intended) with a Haynes manual and checked ok.  Has anyone else had this problem?
95 Honda Accord LX 5-speed
95 Dodge Dakota SLT 5-speed CC
97 Dodge Caravan
(in reply to 19Accord97)
Post #: 9
RE: power windows - 10/19/2007 10:01:34 AM
falkore24
Score: 0
Status: offline
try the accessories while giving the car a little gas.  It sounds like your battery is on it's way out.  If you don't really trust your tester, Autozone can load test your charging system and battery and I believe it's free.
(in reply to white95)
Post #: 10
RE: power windows - 10/19/2007 3:01:34 PM
deserthonda
Score: 0
Status: offline
quote:
ORIGINAL: honda671
Wow.. why are you so bitter.. ??? falkore asked you 2 legitimate  requests and you take it this way ?? And he even used the word Please ..
No Help from me
Post #: 11
RE: power windows - 10/19/2007 8:11:24 PM
white95
Score: 0
Status: offline
quote:
ORIGINAL: falkore24
Yeah, I was afraid you'd say that.  It is definitely worse at idle.
honda671-Make sure your window channels, and the windows themselves, are completely clean.  Then spray all the rubber with silicone.  Then have your battery and alternator tested.  Once you have corrected the problem, post back with the solution so it will come up in a search for others who may have this problem in the future.  And please be more respectful when you do.
Thanks guys.
97 Dodge Caravan
Post #: 12
RE: power windows - 10/19/2007 9:57:19 PM
nafango2
Score: 0
Status: offline
could also be a bad ground. Check the battery for corroded terminals, maybe sand down the terminals / connectors a lil to clean all the crap off them. Also check your grounds like I said before.
While your at it, chillax man.
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2)
Security System / Keyless entry
Post #: 13
RE: power windows - 10/21/2007 3:44:02 AM
honda671
Score: 0
Status: offline
sorry ! guys for being rude and a jerkoff anybody want to spank me for being rude??? but really i am sorry and i am new to this forum so like i really am just learning about this forum
(in reply to nafango2)
Post #: 14
RE: power windows - 10/29/2007 12:36:33 AM
honda671
Score: 0
Status: offline
well today i had sprayed all my window channels and had them clean also,the silicone pray worked out okay and my power windows slide up with ease---
Post #: 15
Page:   [1]
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
