quick question bout springs
Login | |
quick question bout springs - 6/2/2008 12:41:04 AM
umarJ30
so i got a 2006 2dr accord 6speed and im tryin to lower it both for looks and handling. but im not tryin to spend alot of money, so i was thinking about jus getting some springs like the eibach sportlines that drop it 2 at the front and 1.4 in the back. but a freind told me that by getting just springs i would be hurting my car and that i have to get shocks, struts and everything else. and while im on the topic, what is the difference between springs and coilovers? thanks
RE: quick question bout springs - 6/2/2008 7:02:30 AM
finch13
Anything over 1" is going to need new shocks/struts and a camber kit for a decent ride. Use the search feature in my signature to find more info.
_____________________________
HAF SEARCH
RE: quick question bout springs - 6/2/2008 6:22:17 PM
j_man_honda
Joined: 1/8/2007 From: South Carolina Status: offline
Coilovers are a full shock/spring already assembled and just bolts right in place of factory shocks/springs. Coilovers allow you to adjust the height to your liking. As said above, use the search feature
1999 Honda Accord "EX"($11,900- BUY IT) 1996 Nissan 240sx "SE"
RE: quick question bout springs - 6/25/2008 1:41:11 AM
ziwang55
cant u do the the same with eibach sportsline with koni struts/shocks?
RE: quick question bout springs - 6/25/2008 6:24:36 AM
03Sleeper
Yes...but the advantage of coilovers is that they are adjustable. You can adjust the ride height and camber wear whereas the ride height is limited to your spring and you''ll probably have to get a camber kit to go along w/ your shock/spring setup. that being said, coilovers are notoriously expensive.
< Message edited by 03Sleeper -- 6/25/2008 6:25:36 AM >
2003 Accord LX Sedan I4| 5AT 101045 Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
RE: quick question bout springs - 6/25/2008 7:46:19 AM
finch13
Koni''s have adjustable spring perches FTW lol.
HAF SEARCH
RE: quick question bout springs - 6/25/2008 11:51:58 AM
03Sleeper
I thought only Koni Yellows have that feature....or are all Konis Yellow..... *crap* Some KYBs are adjustable as well.
RE: quick question bout springs - 6/25/2008 1:40:45 PM
ziwang55
but does it still work good as a coilover tho?
RE: quick question bout springs - 6/25/2008 1:46:45 PM
finch13
Whatever damper is with the coilover is decided by the manufacturer. Springs and dampers can be mixed and matched, along with sleeve-overs. Think of coilovers as one unit. Sleeper, yes the yellows have adjustable perches, and maybe a few other models too... that''s different from adjustable damping though. With my springs, dampers and camber kits, I could have bought a VERY nice set of coilovers for the same price I will end up paying.
HAF SEARCH
RE: quick question bout springs - 6/25/2008 2:31:00 PM
ziwang55
wait i thought adjustable damping and shock or strut was the same thing? or do they work differently?
RE: quick question bout springs - 6/25/2008 2:53:59 PM
falkore24
Lemme clarify a few things here: Koni''s perch adjusts about 1". It''s only intended purpose is for corner weight balancing, yet it does offer this 1" adjustment and can be used for aesthetics as well. Adjustable dampening is done from the shock or strut. This makes the ride harder or softer. A coilover, sleeve-over or coilover sleeve allow the height of the car to be adjusted via variable height, threaded spring perches (typically about 3" of range). A coilover may or may not also use adjustable dampers. Not all Koni''s have the adjustable perches because the ones that I''m probably going to get for my Scion don''t.
2006 Scion TC Short Shifter radiator panel fully lit 3rd brake light strut bar 4pt rear bar sways S-pipe pulley poly bushings poly mounts ETD air horns pending ZPI turbo system 2000 V6-AT (RIP 3G
RE: quick question bout springs - 6/25/2008 2:55:37 PM
falkore24
quote:
ORIGINAL: klrspz Koni yellows have the adj. perches.. dunno about the others... what''''''''s a good coilover cost that does all the standard adj. plus damper adjustments? I think i paid under 1200 for my koni+eibach setup over a year ago. I think that I paid just under a grand for the Tein SS setup that I had ..... about 4 years ago ..... before gasoline drove up the price of our mods!!! NOTE: If you want the EDFC control system, you have to get the Tein SS-P setup, not the SS.
< Message edited by falkore24 -- 6/25/2008 2:56:44 PM >
RE: quick question bout springs - 6/26/2008 1:37:17 AM
ziwang55
well tell us about ur tein setup how was it performance wise?
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
