test an ignition coil?
  Printable Version
Honda Accord Forums >> Other >> HAF Help & Suggestion Center >> test an ignition coil? Page: [1]
Login
test an ignition coil? - 6/23/2007 7:36:06 PM
randy93
Status: offline
my 93 honda accord just died while driving. i have no spark to my sparkplugs.  what is best way to check my coil ? any advice will be appreciated!
Post #: 1
RE: test an ignition coil? - 8/14/2007 3:27:56 PM
kevcann3
Status: offline
put a driver in the coil wire put it close to a pice of metal and turn it over you will see the spark (dont touch the metal on the drive and do this some where there aint to much light) good luck...this is the old school way ...or get a volt meter
(in reply to randy93)
Post #: 2
RE: test an ignition coil? - 8/14/2007 3:56:24 PM
sir_nasty
Status: offline
Have you inspected your cap/rotor?  Is the coil wire connected properly or did it wiggle loose?
_____________________________
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Quote: Life''s great but it''s not all beer and skittles
(in reply to kevcann3)
Post #: 3
RE: test an ignition coil? - 8/15/2007 4:30:20 PM
deserthonda
Status: offline
go to our DIY section and read up on it ,,scroll till youi find the post
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 4
RE: test an ignition coil? - 11/17/2007 9:08:16 PM
javier_josue
Status: offline
the ignition coli have 4 terminals to check if its ok you grab an ohmimeter and check the resistance betwen terminal a and c of the coil it shoul be betwen 0.7 or 0.8 ohms then check the betwen the secondary and the a terminal it choul be around 22,000 ohms if this its correct the coil its good
what you do next is with the car ignition on you check if you got batery voltage in the 2 primary wires of the coil if you got 12v the you hook a test ligth to the positive batery terminal and the other end in the coil signal then you try to start the engine if the ligth blinks but you dont have any spark the coil its bad if the ligth doent blink check the ignition distributor or icm (ignition control module) inside the distributor
i hope you fix your problem good luck
(in reply to deserthonda)
Post #: 5
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
