trouble retrieving codes
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> trouble retrieving codes Page: [1]
Login
trouble retrieving codes - 8/19/2008 3:36:06 PM
Erinsaccord
Status: offline
95 Accord, 4 cylinder auto (non-vtec).  This has happened three times, and I hope that someone can help me.  The CEL comes on, I use a paper clip to create a connection between the two terminals on the service connector, and the CEL immediately goes off.  It stays off for several weeks (maybe 25 or so cranks?) and then pops back on.  What''s up?
Thanks, Dave
Post #: 1
RE: trouble retrieving codes - 8/19/2008 3:55:46 PM
hondadude
Forum Monitor
Status: offline
Have you tried to insert the jumper first, Then turn on the key?
_____________________________
This post was made by a REAL Hondadude, not the wanna be Honda_Dude
85 Yota pickup 235k miles "never say die" 22r engine.
92 Acura Legend 70k miles. Wife lets me drive it for oil changes.
(in reply to Erinsaccord)
Post #: 2
RE: trouble retrieving codes - 8/19/2008 6:32:39 PM
Erinsaccord
Status: offline
Dude,
Yes, that is the protocol I have followed, per instructions.  It''s almost as if the procedure functions as a switch to turn off the light.
(in reply to hondadude)
Post #: 3
RE: trouble retrieving codes - 8/19/2008 7:28:04 PM
PAhonda
Status: offline
This link has a good set of instructions:  http://www.dhost.info/accordinfo/howto/cel.html
Make sure that you use a thin paperclip and that it is securely touching both metal leads in that plug.
1995 Accord EX MT
Post #: 4
RE: trouble retrieving codes - 8/19/2008 9:46:14 PM
JimBlake
Status: offline
If theres no error code stored, the lamp is supposed to stay on solid.  Unfortunately, if the CEL is on, then goes OFF when you plug in the jumper, the problem might be a bad ECU.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to PAhonda)
Post #: 5
RE: trouble retrieving codes - 8/20/2008 5:31:58 AM
Erinsaccord
Status: offline
Jim,
How would I determine if it''s a bad ECU?  Would it be worth grabbing one from a junk yard to switch out?
(in reply to JimBlake)
Post #: 6
RE: trouble retrieving codes - 8/20/2008 8:01:34 AM
JimBlake
Status: offline
If cheap, try the swap.  I usually dont like throwing parts at it without diagnosing, but dont know how to positively test for this.
The Helm book says to try a new ECU, but thats easy for them to say - they dont have to pay for it...
Post #: 7
RE: trouble retrieving codes - 8/20/2008 3:48:51 PM
Erinsaccord
Status: offline
Took a look at the ECU this afternoon.  There are two units there, one marked for the transmission, the other for the engine (?). I didn''t take them off the platform they are mounted on. What''s troubling me is that the two wires that you jump together according to the online protocol don''t go to the large ECU, they go to the unit marked for the transmission! The other connector''s three wires go to the larger unit, presumably the engine''s ECU.
This leads me to think that I am not testing properly and that the sudden turn-off of the CEL is proper.  Could it be that I have an early OBD II car that can be scanned using the three-wire connector?
Post #: 8
RE: trouble retrieving codes - 8/20/2008 5:47:09 PM
hondadude
Forum Monitor
Status: offline
Pull out the ashtray and see if there is an OBD2 plug behind it.
Also the under hood sticker should say if the car is OBD1 or OBD2
Post #: 9
RE: trouble retrieving codes - 8/20/2008 6:10:18 PM
Erinsaccord
Status: offline
Yeah, I checked under the hood and it is definitely OBD I.  Also, nothing available behind the ashtray.  BTW, what''s the other service (three wire) connector for?
Perplexed.
Post #: 10
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
