twin turbo help
Login | |
twin turbo help - 10/19/2005 1:11:35 PM
flomasta
im kinda new to the turbo tech and specs but i do no most of the basics. i wuz wonderin if you gonna go the twin turbo route on your car if two differnt sized turbos is gonna be effective. a smaller one so there is less spool up and less lag, then a larger one to produce the heavy boost to really get goin. I thought i herd something like that somewhere so i thought id ask. thanks
RE: twin turbo help - 10/20/2005 12:47:00 PM
Patrick
with what motor? when you have two turbos feeding into the same TB they would need to be the same size, but if youre running a system as on the 2JZ, where one turbo feeds the next turbo, which in turn feeds the TB, typically, yes, the first turbo is smaller, thus reducing spool time
