valve adjustment - how necessary is it?
  Printable Version
Honda Accord >> Your Ride >> Engine & Internal >> valve adjustment - how necessary is it? Page: [1] 2   next >   >>
Login
valve adjustment - how necessary is it? - 11/27/2004 5:58:38 PM
eleiko
Status: offline
Last week I got a tune-up at 160,000 miles. The mechanic didn't adjust the valves, nor did he adjust them at last tune-up (133,000). It's his opinion that valves don't need adjusting unless the car rides rough, which it doesn't. He knows that Honda recommends a valve adjstment every 15,000 miles , but thinks it doesn't make sense. Any opinions here? Thanks.
Post #: 1
RE: valve adjustment - how necessary is it? - 11/27/2004 8:44:51 PM
poff1986
Status: offline
poff1986's photo gallery
valve adj. should be done every 30k on hondas unless a "V6"...the technician obiously doesnt usually work on hondas..and if its a honda dealership he needs to go through Honda certification if he says that..your car needs valve adj. 30k, 60k, 90k, 120k..etc...GET THEM ADJ.!
_____________________________
SOHC VTEC
(in reply to eleiko)
Post #: 2
RE: valve adjustment - how necessary is it? - 11/30/2004 8:32:18 AM
RTexasF
Forum Monitor
Status: offline
RTexasF's photo gallery
I agree, have it done. Even if the car is running well better mileage and performance could be realized with the adjustment. A quieter engine is another possibility.
< Message edited by RTexasF -- 11/2/2005 5:42:46 PM >
(in reply to poff1986)
Post #: 3
RE: valve adjustment - how necessary is it? - 12/17/2004 1:06:20 PM
ElectricTwilight
Status: offline
Here's the thing...you can never go wrong with a good valve adjustment...you will notice a difference even if you thought the ride 'felt fine'....dont wait till there's a problem to fix it...
(in reply to RTexasF)
Post #: 4
RE: valve adjustment - how necessary is it? - 10/31/2005 9:35:05 PM
FlyLow
Status: offline
In owners manual for 99 Accord, it says to "Inspect Valve Clearance" and the very first interval is scheduled for 105K, until then it says to "Adjust only if noisy". So according to the manual adjustment should be made only if valvetrain is noisy before the 105K mark. Same interval is used under Severe Driving conditions, as for the Normal Driving. So how noisy does it have to be? The check must be done whith the engine cold, so what kind of noise should one be looking for, from an already noisy cold engine? Mine makes chattering sound when cold, it could be the sound from the valvetrain but it goes away as engine warms up. I was told by an aging auto repair guru, that the noise from valves when cold means that there is clearance, it would be bad if there was no noise since it could mean that valves don't get to close all the way or something like that. So I guess I am looking for more insight into this valve noise , is it good or is it bad. Oh, and why wouldn't the owners manual say anything about valve adjustment every 30K.
Thanks much!
(in reply to ElectricTwilight)
Post #: 5
RE: valve adjustment - how necessary is it? - 10/31/2005 10:43:02 PM
Evlampius
Status: offline
big waste of money
(in reply to FlyLow)
Post #: 6
RE: valve adjustment - how necessary is it? - 11/1/2005 4:02:43 AM
FlyLow
Status: offline
Local Honda dealer gave me an over the phone price of around $185 for the adjustment, said takes about 2 hrs. Should I do it?! So tempting I was intrigued by a few people saying earlier, that better performance may be realized. Although I think my 99 LX is doing well, I get 28-30 mpg. Any thoughts?
(in reply to Evlampius)
Post #: 7
RE: valve adjustment - how necessary is it? - 11/1/2005 11:14:23 PM
LinX
Status: offline
Ask around before u go spending unnecessary cash. It's not all that necessary IMO unless youre ride is totally off.
I have a Ferrari........diecast metal model that is. :)
Post #: 8
RE: valve adjustment - how necessary is it? - 11/2/2005 2:06:18 AM
FlyLow
Status: offline
It's just that those super member guys from earlier posts got me worried, they said get it done even if the car is running well, which it is. I wana get to the bottom of this. Is it a waste of money or is it a good thing to get done? The Haynes repair manual says: "The valve clearance generally doesn't need adjustment unless valvetrain components have been replaced, or a valve job has been performed." If you got the car used, how would one know if anything had been done to the valves?
(in reply to LinX)
Post #: 9
RE: valve adjustment - how necessary is it? - 11/2/2005 5:44:45 PM
RTexasF
Forum Monitor
Status: offline
If it's never been done it is past due @ 133,000 miles. It's as simple as that! I think it would be worth your while to shop however.
< Message edited by RTexasF -- 11/2/2005 5:46:35 PM >
Post #: 10
RE: valve adjustment - how necessary is it? - 11/3/2005 1:12:52 AM
FlyLow
Status: offline
Where did you dig that number up Tex? Just curious
Post #: 11
RE: valve adjustment - how necessary is it? - 11/3/2005 8:49:16 AM
RTexasF
Forum Monitor
Status: offline
quote:
ORIGINAL: FlyLow
That's called DUH! I should have said 160,000 miles, sorry.
Post #: 12
RE: valve adjustment - how necessary is it? - 11/3/2005 12:45:33 PM
FlyLow
Status: offline
I am only half way there, 80K
Post #: 13
RE: valve adjustment - how necessary is it? - 11/11/2005 12:33:53 AM
7thGen
Status: offline
If you are concerned you can have the clearance checked. It is not that hard to do. Some of the noise could be injectors. My 03 sounds like it needs a valve adjustment but is just injector noise. On pre-03 4cyl the valve clearance should be at least checked every 105k. Prior to 98 it should be more often.
Post #: 14
RE: valve adjustment - how necessary is it? - 11/11/2005 9:01:32 PM
FlyLow
Status: offline
quote:
ORIGINAL: 7thGen
I can check clearance myself? What does your injector noise sound like? (describe if you can) Is it no cause for concern?
Thanks ahead of time
(in reply to 7thGen)
Post #: 15
Honda Accord Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
