06' bulb replacement
Old Mar 5, 2006 | 02:41 PM
dave118811's Avatar
Default 06' bulb replacement
I want to change the look of my headlights, so im looking to change the bulbs just for right now. someone suggested the EuroDezigns Blue 8500K. but i dont know which one is for high beams and which one is for low beams? www.eurodezigns.com is the site. help please?
Old Mar 5, 2006 | 03:09 PM
Default RE: 06' bulb replacement
Might I suggest the SilverStone bulb replacement available at AutoZone..Bright White and throws out a larger light pattern than standard lights. Put in both Lower/brighter for that good lighting effect.
Old Mar 5, 2006 | 03:20 PM
03AccordEX's Avatar
9006 Type bulbs are the low beams and 9005's are the high beams (I doubt they've changed since 03)
Save yourself money and hassle and buy yourself some nice Sylvania Silverstar bulbs at AutoZone. They'll last a heck of a lot longer than those will, and they look much better.
Old Mar 7, 2006 | 12:05 AM
dave118811's Avatar
can someone confirm that the 9006 is the lowbeam and 9005 is the highbeam before i buy them?
Old Mar 7, 2006 | 12:48 AM
03AccordEX's Avatar
I'm 99% sure they're the same. Even with the DRL's. Plus, just ask at AutoZone, they can tell you what bulbs you need.
Old Mar 7, 2006 | 08:10 PM
sexybeast06's Avatar
Yes the 9006 are the low beams and the 9005 are the highbeams. I have an 06 also and just like 03accordex said he's 99% I'll be that 1% to make it 100% sure. If your still unsure go to the sylvania site to check right here. http://www.sylvania.com/ConsumerProd...de/default.htm
Old Mar 7, 2006 | 09:10 PM
03AccordEX's Avatar
ORIGINAL: sexybeast06
Ha thanks. I was looking at that website too, but noticed it only goes to 2005. Oh well. [:@]
Old Mar 7, 2006 | 09:13 PM
The lights and bulbs has not changed from the 05-06 headlamps, only the back lights which are now LED.
Old Mar 17, 2006 | 02:24 AM
RoXeTTeMaN's Avatar
I have Nokya Purple White on mine. It gives kinda purple-blueish light beam, much brighter than stock. I bought mine on Ebay. Not so proud but I hated the way stocks looked like. I'm planning to buy HID kit and aftermarket headlamps with projectors any time soon. Anyone recommends any brand that I should go with? JDM? McCulloch? Phillips? Mtec? Thanks for any help.
tougefreak
Aug 21, 2007 11:55 PM
indy49
Jan 30, 2007 01:18 PM
sskkf
Jan 19, 2007 04:23 PM
eckhart
May 27, 2006 07:40 PM
tiffany
Apr 29, 2005 07:17 PM
