06 Coupe inner door seal separating from frame.
Old May 18, 2014 | 09:23 AM
MysticBlueEX's Avatar
Almost A Senior Member
Default 06 Coupe inner door seal separating from frame.
Both driver and passenger sides have the same problem. The upper corner of the inner door seal is separating from the inner door frame. I would like to get them right and glue them back permanently. It seems like the frame that holds the rubber has shrunk, or pushed out of place from the door open and closing. I figure that the weatherstrip needs to be removed from the entire door and then re-installed correctly.
Has anyone fixed this? how did you do it, and how long did it last.
Old May 29, 2014 | 11:33 AM
RedsHonda's Avatar
Default get in the zone
You can get a nice bunch of that from your local autoparts store. I got some for my car there for about $30. Diff stores carry diff stuff. So if silicone or glue won't hold you can get it locally in most cases.
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
JPodAccord
May 26, 2012 05:10 PM
cadreck
Mar 9, 2011 12:59 PM
larrypac
Jan 4, 2009 01:48 PM
