2016 Sport, which headlight bulbs to match fog lights?
Kensun should be a good brand. You can use a relay also if you want to try that . I'm using a 35w 5500k ultra hid from Ddm and it was just plug and play. I do recommended getting an AC ballast and not the DC ballast. Not sure what the Kensun uses. You can search on YouTube why AC is better than the DC .
I had the exact same symptoms with the TRS 50W HID kit, and after a ton of troubleshooting including using 2 separate relay harnesses and ruling out ballast and igniter defects, it turned out to be a defective bulb.
Please let me know what bulb size should I get for a HID kit for my 2016 Coupe EX-L.
I think it is H11 but just want to confirm with someone that has already changed the horrible halogen lights the car comes with.
I haven't seen posts about also replacing the high beams with HID lights.
Please let me know if it is possible to replace both the low and high beams.
If I buy the kit from Xenon Depot what option should I get with the lights? with
CANbus or Mopar?
Thanks for your help
CANbus or Mopar?
Hello all, I am new to the forum. I purchased an HID kit for my accord and I am having trouble installing them. There is not enough space for me to get the bulb out and mount the ballast. Is there a simple way to make room in there? What needs to come out to make room? Any help would be greatly appreciated. Thanks.
Turn signal: switchback LED from superbrightled
Brenton Thornicroft
Jan 1, 2014 01:33 PM
Ntegra
Oct 9, 2006 12:37 AM
