low beam headlight
one of my low beam head light is higher than the other. how do i adjust it? how do i kno if it too low or too high?? thanks
RE: low beam headlight
pop the hood and look at the back of the headlight, there is usually a couple of screws that you can twist to adjust (use a long handled screwdriver) the easiest way to do it is park in front of a wall about 6 feet back from it and then you can see where the lights are hitting and adjust them to the way you want them.
how do i kno if i'm adjusting the light too high or too low? where is the right place??
adjust them to be equal then drive around and see if you like the way it looks. if you get flashed its probably too high hahaha. other than being too high i think its wherever you can see the best.
In most cases, your lights should be slightly lower than perfectly horizontal.
