01' coupe fog lights
Does anyone know where to find some fogs for my 01' coupe? I've seen plenty of the setups for the 4door on Ebay, but not 1 coupe set. Are they the same kit or is there a kit made just for the coupe?
RE: 01' coupe fog lights
Well then. Another question noone seems to know the answer to.[sm=dontgetit.gif]
Boy, been wondering the same thing for my 01 V6 coupe. It's like there's foglight kits for exery year but 2001!! I can bolt-on anything, but that nice clean OEM insert would be a cleaner install.
One of my fog lights is cracked (01 coupe as well) and this is the only place i found that has them. Alhtough they are pretty expensive.
http://www.handa-accessories.com/accext01.html I want to know if any other foglights will bolt into the factory locations, because if i have to spend that much money i would rather get a high performance set for the same price, expecially since i already have the factory inserts. |
Yea, I checked out H & A, but found the kit cheaper on ebay. Do a search for "01 accord fog light" & you'll find it for $220.
No other foglight will fit into the OEM setup, but some small projector-style would probably do the job once you have the right insert piece. Check out this one: http://cgi.ebay.com/ebaymotors/98-99...spagenameZWDVW |
here's the link to the fog light kit:
http://cgi.ebay.com/ebaymotors/ws/eB...0132647&rd=1,1 I called them prior to them listing it for $219.95. They said it was $243 over the phone & then I saw that they listed the kit on eBay about 2 hours later. So, $219.95 is a good deal, but too expensive for just fog lights. They don't add enough looks or light for that price. I'd rather upgrade my headlights to HID. |
I agree that they are just too expensive. They are not as bright as high performance ones for the same price, and do not add anything other than looks really. If i cannot find a set that will bolt into the factory location then i will most likely just leave them be.
so, what do you think about those inserts that i linked to above? some small projectors would probably work with those inserts. no matter what, though, the front bumper needs to come off. it is really easy. i have the haynes manual & it shows 15 or so screws that come out & then viola! anyway, not worth it.
Yeah i do not think it is worth it. The inserts look ok, but if they only stick on with tape i am not sure how good it would hold. Plus on top of that you have to get the actual fog lights.
