'05 Accord & Parrot MKi9100
hi,
I recently purchased and installed a Parrot MKi9100 for my 05 Accord, great system. Installation was easy, with the help of the following cable, PC000008AA. I also purchased Parrots UNIKA system which allows you to control the hands Free kit using the Steering wheel radio control buttons. Here's where things get tricky, you need to manually set 4 jumbers on the UNIKA for either a Resistive or, CAN BUS (KBUS) Radio system. Does anyone know if the Accord is Resistive or CAN BUS and where is the Electrical connection for this to be found? I've done a bit of searching and based on the following link, think that it is CAN Bus but, don't fancy removing the Speedo to get at it. If there's an easier way to get to this connection i'd apprediate the heads up. http://www.racelogic.co.uk/_download...N_GUIDE.pdf#10 Thanks |
