99 accord, backlight, turn signals doesn't work
so the clock backlight went out, i ended up replaced the whole hazard switch and clock module. the replacement i got supposed to work for all years from 98-02.
after the replacement, all backlights and the turn signal no longer work. i have checked the fuses, they are good, and the weird thing is that: if i press the hazard switch, the backlights came on, but not the hazard signaling .. :confused: i put back the old hazard switch, the hazard signaling still work, but backlight still isn't working, wonder what i have busted from this process.. sigh.. :mad: (it is a 1999 accord) any pointer would be appreciated.. |
what do you mean by all back lights? Reverse lights? What about individual signaling? Not doing hazards. Parking lights, brake lights ect...
i mean the instrument panel backlight, sorry for not being clear.
the turn signals works. |
How many plugs are there? You may have them backwards. If not that, do the dash lights without the hazard/switch clock plugged in? If not that either, you may have picked up a switch you thought was new. May have to get a brand new one.
