09' Adding subwoofers
I am going to be adding a couple Rockford P2's that I have laying around. I plan on just using a line output converter and hooking them to the stock system. Anyone know what color wire to spice into for the remote wire? Also, is there anything else I should look out for when doing this?
Kinda crude but I always just ran a wire from a fuse that gets power with the ignition like the radio fuse. You just need a small current to turn the amp on. Some amps, not many though, have current sensing so theyll come on when they sense voltage in their inputs.
there is a remote turn-on output from the head unit, but it is sometimes missing from the HU harness.
if your vehicle has Active Noise Cancelling (ANC) you will need to defeat this feature. |
Originally Posted by keep_hope_alive
(Post 295251)
