'12 SE USB port dead
I recently bought a '12 Accord SE. When I connect my iphone 5 to the USB Port, the phone doesn't see any 5V USB power and the stereo doesn't see the phone. I also tried an ipod 3G with the same results. The adjacent 12v outlet works. Key on or off doesn't matter. Any ideas? Fuse?
SL |
it's possible the 2012 doesn't provide charging for a larger device, just data transfer or enough for a thumb drive
As stated, the radio does not even see the phone when plugged in, despite being reportedly compatible. I'm hoping there is a bad fuse somewhere, but suspect something deeper. Before tearing into the center console, I'd like to at least have a wiring diagram, but have been unable to find it online. Does anyone know of a link to one?
Thanks, SL |
There is no fuse solely for the USB port. The USB circuit consist of the port, a USB adapter unit in between the port and the audio unit, and two separate wiring connectors for the wires.
the pin-out for the USB connector will match industry standard so you can start by looking for 5.1VDC on the power pins.
