1996 accord EX Keyless entry installation
Old Mar 31, 2018 | 03:34 PM
ahelmer's Avatar
Default 1996 accord EX Keyless entry installation
Hi everyone, I joined this forum because I am working on my 1996 Accord Ex.
I have been reading the other posts on installing keyless entry systems and I am almost there.
I purchased a Avital keyless entry and as I was installing it I realized that the previous owner had done the same, and must have lost the remote. I almost have it hooked up except for the last wire. Please excuse my ignorance of electrical systems. I have lock and unlock connected, but from what I have been reading I need to find the negative door trigger. I actually took apart the switch on the door panel and hooked the 3 wires directly into there and the remote worked. Constant current, ground, and parking flash wires are all connect, I just need to find (what I think is the negative triggered ) under the dash, or if there is any other way to wire. Any help would be appreciated.
Attached Thumbnails 1996 accord EX Keyless entry installation-20180331_140527.jpg   1996 accord EX Keyless entry installation-20180331_140425.jpg   1996 accord EX Keyless entry installation-20180331_140200.jpg   1996 accord EX Keyless entry installation-20180330_205128.jpg   1996 accord EX Keyless entry installation-20180331_151740.jpg
Old Mar 31, 2018 | 07:08 PM
It took a little while to understand what you were asking, as the title of your thread is misleading. Your question is asking about the wire to trigger the alarm when a door is opened. There are keyless entry systems that are not part of a security system.
For the door open input wire to trigger the alarm, there is a Blk/Wht wire (-) coming from the gauge assembly (aka cluster) to a 20P gray connector (Connector C435) located to the right of the steering column. The Blk/Wire is at pin 5 of Connector C435. That is the same wire used by the optional Honda security system and the stock security system on SE models.
Attached Thumbnails 1996 accord EX Keyless entry installation-connector-c435.jpg
Old Mar 31, 2018 | 08:29 PM
ahelmer's Avatar
I think its because Im still learning termonology. Should I rephrase the question? I just want the lock/unlock to work, and it isnt.......
Old Mar 31, 2018 | 08:36 PM
This photo appears to already show the lock and unlock wires tapped into at Connector C425, located under the driver's dash, above the kick panel. The door locks are negative trigger.
Attached Thumbnails 1996 accord EX Keyless entry installation-connector-c425.jpg
Ojie
Feb 24, 2014 12:28 PM
daanish_b
Aug 8, 2013 01:31 PM
Mpwr
May 31, 2006 11:53 PM
sastone75
Nov 18, 2005 08:38 PM
93Miata
Nov 10, 2005 08:06 AM
