1996 Accord LX Radio issues
The radio is having issues with flickering lighted display then other times any illumination completely disappears and then everything lights up even the preset buttons, I mean all of them light up at the same time, the radio stations that are preset preset stay put so its not losing power but nothing is illuminated.
Does anyone else have or had this issue? remedy's? Do I need a new radio? :shrug: Thanks, Chris |
Originally Posted by Twisted
(Post 377690)
Does anyone else have or had this issue? remedy's? Do I need a new radio? :shrug: Thanks, Chris 1. someone has made changes to the wiring and you have a poor connection. Look back there and if you find any aftermarket connectors, replace all of the connectors with quality crimps or solder. 2. If the wiring is 100% stock then I would expect a radio issue (known problem with age) |
Originally Posted by keep_hope_alive
(Post 377702)
I suspect one of two issues.
1. someone has made changes to the wiring and you have a poor connection. Look back there and if you find any aftermarket connectors, replace all of the connectors with quality crimps or solder. 2. If the wiring is 100% stock then I would expect a radio issue (known problem with age) Thank you. |
