1997 Accord Door Panels
How difficult is it to remvove them to replace the speakers? Any links to diagrams of how to so it? Thanks!
RE: 1997 Accord Door Panels
Hey! I changed my speakers in my door not to long ago on my '97! Removal in of the doors is simple. I made a tutorial here: https://www.hondaaccordforum.com/m_3..._/tm.htm#39008
Its not the best, but it shows where all the bolts and screws are to remove it. It is simple, although when you put it back on it may feel as though you just messed up your car but you havent! I had never done it before that post and it doesnt really require any special things. Like in that tutorial, make sure you have the correct speakers. Hondas require thinner speakers which will narrow your selection. Let us know how it goes or if you need any more help! Good luck! |
Thanks! Can I create an wedge to angle the speakers or is there too little room? I would try and modify the panel so I can carry two 5 1/4"s in the door, if not TOO much work...
Not to sure about a wedge, as the space is already tight.
