2002 Accrod Sedan Odometer Bulb
My sister's '02 accord's odometer bulb is burnt out. How hard is it to replace/get to? I know on some cars its very easy and some can be a real pain.
I just did mine and it took less then 15 minutes: http://forum.miata.net/vb/showthread.php?t=399092 Thanks, Mark |
it's easy. in front of the instrument cluster is a trim piece with two screws on top (use a stubby phillips). once that is off, there are like 4-6 screws or 10mm bolts holding the instrument cluster in place. remove those then work the instrument cluster out.
Be patient as you'll have to unplug the three wire harnesses before it comes out completely. the bulbs unscrew with a quarter turn. you can buy them at a local dealership or at hondapartsdeals dot com. |
great, thanks!
