2003 Accord keyless lock problem
I have a 03 av6 and the keyless entry dont work. it unlocks all doors sometimes except drivers door it never unlocks or locks. truck pops up fine. battery is good in the key. took it to honda dealer wants 450.00 for changing actuator in drivers door. any help in this issue needed also stated not cov under warranty i have 7yr 100K warranty. car has 45K. any suggestions or help needed
RE: 2003 Accord keyless lock problem
Call Honda Customer Relations to see if they will authorize it:
http://automobiles.honda.com/informa...relations.aspx |
I just had my dealer here in Canada change my passenger side acuator for a $25 deductable. Mind you, I have a comprehensive warranty on the car. If you have the same warranty, I would guess you should be given the same deal, otherwise I would imagine calling customer relations would be your next best step.
A last resort if they won't cover it is to go to HondaPartsDeals.com and order the acuator from them. Its usually waaaaay cheaper. When I was looking at the passenger side of my '03 it looked like it shouldn't cost more than $100 + shipping. If you don't know how to install it, the dealer might install it for you or take it to a mechanic. Either way, buying from the forementioned website will save you money as the dealer will charge a lot more... as you mentioned... $450!?!?! |
