2003 .. lite & siren Install
Installing emergency lite & siren... looking for plug & output wire color code for fuse 29 of interioir fuse panel ... fuse 29 not used in this vehicle.. need keyswitch voltage to tie into ....
Just use an Add-a-circuit in the No. 29 unused fuse box slot.
http://www.littelfuse.com/~/media/Fi...FHM02FHA02.pdf |
add-a-circuit can work great as long as the pins are actually there. some of the black holes also lack adequate pins.
did you use a DMM to verify the location has switched +12V? |
