2006 Accord sedan SQ Audio build
8 Attachment(s)
This is a sound quality build I did for a friend that owns a 2006 honda accord sedan.
sedan. The goal of the system will be a stealth build where everything in the trunk will be out of sight. Goals of build: -Provide Great sound quality while sticking to budget -stealthy trunk build and leave as much space possible for daily use The list of products Pioneer DEH-80prs Headunit Mosconi 6to8 DSP Mosconi Gladen one 120.4 amp Mosconi Gladen one 240.2 amp Image Dynamics IDQ10D2 V.3 10" subwoofer Illusion Audio Carbon C6 6.5" components Attachment 17388 The pioneer 80prs was installed using Bestkits install in lower storage pocket. Attachment 17389 Attachment 17390 Attachment 17391 next moving onto the doors, removing the panels and treating sheet metal with focal Bam XXXL and Blackhole tile. Attachment 17392 Attachment 17393 Attachment 17394 |
1 Attachment(s)
Next adapters
where made from 3/4" mdf for the front doors to mount the illusion audio c6 mids. Then adapters were sprayed with bed liner. Attachment 17387 |
1 Attachment(s)
1 Attachment(s)
2 Attachment(s)
Next the tweeters were installed in factory location to have a stock appearance
Attachment 17383 Attachment 17384 |
2 Attachment(s)
Moving on to the rear doors, they received the same treatment as the front doors
Attachment 17381 Attachment 17382 |
4 Attachment(s)
I ran 1/0 gauge power wire to power the system on the driver side and ran the signal wires down the passenger side.
Attachment 17377 .Attachment 17378 Attachment 17379 Attachment 17380 |
6 Attachment(s)
Moving onto the trunk, a 3/4" mdf base was mounted to the spare tire area to house the amp rack and a sealed .75 cu.ft enclosure. screw rivets were used to secure the base to the car.
Attachment 17371 Attachment 17372 Attachment 17373 Attachment 17374 Attachment 17375 Attachment 17376 http://i562.photobucket.com/albums/s...ps08882ab6.jpg |
5 Attachment(s)
Attachment 17366
Next the trim panels are cut, routed and sanded. Attachment 17367 Attachment 17368 Attachment 17369 Attachment 17370 |
2 Attachment(s)
Attachment 17364
The trim ring that hide the sub woofers screw mounts in place using neo magnets Attachment 17365 |
